SOURCE: Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
SOURCE: Freezer keeps beeping and switching off
Next time this happens unplug it for about 10 minutes. When you plug it back up you should be able to turn it back on normally. This resets the board, much like restarting your computer. If the problem happens again, you will probably have to replace the board. You also want to make sure you have a good ground on the circuit and a steady power supply without too much fluctuation. Hope this helps.
SOURCE: Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
