Question about Logitech Computers & Internet
Where is the serial number on my new logitech hd pro webcam c 920
Posted by Phil Aissa on
5 Related Answers
JulesPCaut
Jules Peters
  • 702 Answers
SOURCE: Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Posted on Jun 22, 2009
Anonymous
  • 94 Answers
SOURCE: pls help me find the driver for my webcam logitech
Try this link and search for your model by looking at the Search by Product dropdown box category. "http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/entry.php"
Posted on Jul 03, 2009
rexark
rexark
  • 55 Answers
SOURCE: Final Cut Pro installation problem
At the risk of being too simple, it really sounds like the Serial Number is not valid -
Check O's and I's - try zeros and ones
Better, copy the serial number from a place where you know it is correct, then paste it into the first box - it should paste correctly into all the boxes and you should get an OK button ...
Or paste the individual sets of numbers into each box if you need to ...
Good luck, hope you get it worked out!
PA Systems for Small Groups DVD - rexark.com
Posted on Mar 07, 2010
Anonymous
  • 8637 Answers
SOURCE: ids_error_install running while installing new
Copy this site and paste it in your web browser address bar and hit ENTER.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
From the images, select the webcam and then download your cameras driver.
Then to install and use it on the Web, do this.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Sep 20, 2010
dan5268
Dan Shibata
  • 542 Answers
SOURCE: serial number Magix MOVIE EDIT PRO 17 HD PLUS
The serial number is provided when you purchase the software, if you can't find it you should contact Magix Tech support
Posted on Apr 10, 2012
Where do i find the serial number for logitech C615 hd webcam
It should be on the box it came in, as a barcode and text.
or you can sometimes download the computer software and it will identify it in Properties
https://support.logi.com/hc/en-us/articles/360024361233
Or you can ask them direct
https://support.logi.com/hc/en-us/requests/new?ticket_form_id=360000621393
Here is you manual, just because I came across it.
https://www.logitech.com/assets/38467/3/hd-webcam-c615-gsw.pdf
Lost connection to computer
Unplug webcam from computer. Shut down computer. Connect webcam to computer. Re-boot computer. You might do a web search for: Logitech HD Pro Webcam C920 driver, if you don't have a CD that came with the webcam.
HD Pro Webcam C920 V-U0028 860-000334 LWS 2.40 LWS
If you're looking for a Windows Driver for this WebCam, try this location:
http://www.logitech.com/en-us/support/5798#section=downloads
From there, you select the appropriate operating system from a dropdown menu, then you can download the correct software for your hardware.
Good Luck!
1helpful
Driver needed for logitech webcam serial number 501484-2000
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administration tools ,computer management ,device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver if you dont have the driver you will need to download one http://download.cnet.com/logitech-quickcam-pro-camera/3000-2108_4-10028593.html
Driver for logitech serial number 501484-2000
I hav lose my device driver cd 802.11b/g wireless usb adapter
your best bet is to look at your usb adapter and see if you can find the make and model number of the wireless adapter, go to the manufactures page, there should be an option to download the drivers from there, for example:
Webcam
Logitech : Manufacture
Model: HD pro webcam c910
so you go to Logitech.com - prodcuts - Click on HD pro webcam c910 - support- then downloads
Hope this helps if you could state the name of your wireless usb adapter i could link you :)
Will a Logitech C500 Webcam work with an newer Mac Mini ?
UNIQUEMENT AVEC QT PRO, LES TYPES DE BEST BUY N'Y CONNAISSENT ABSOLUMENT RIEN!!!
The Logitech article on UVC lists the C500 as a supported camera, but also says:
"NOTE: With the exception of the QuickCam Vision Pro for Mac, all other UVC cameras are not officially supported on the Mac and some features or application support may not work."
Product ID: 0x0807
Vendor ID: 0x046d (Logitech Inc.)
Version: 0.09
Serial Number: F68AC850
Speed: Up to 480 Mb/sec
Computers & Internet Logo
Top Logitech Computers & Internet Experts
Ekse
Mehandi Husain ...
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
