SOURCE: Ricoh AP610N error message SC-545
Hi, i recently got this error on Ricoh Aficio AP 610N
and This was the Fix..
0.- Hold on your breathe...
1.- Turn Off the printer.
2.- Press "ONLINE and SCAPE" buttons..
3.- without stopping pressing them (ONLINE and SCAPE) TURN ON THE PRINTER.. and wait about 10-15 seconds and Service menu show up.. after this.. release the buttons...
4.- Go to.. Engine Maintenance... Enter..
5.- Search for SP5810 (Fusing err clr) and Enter.
6.- Accept the change and enter...
7.- Turn off the printer...
8.- Finally turn on the printer and try to print something :)
9.- if the printer works.. you can breathe again :)
Thanks to everybody..
SOURCE: error e51 on zanussi iz12
E51 does mean "triac which powers the motor short-circuited".
(TRIAC short-circuit cut-out activated or motor speed more than maximum speed)
Possible causes:
Loss of insulation on motor winding/wiring; main PCB
Dado
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
