Question about Samsung PPM50H2 50 in. Plasma Television
PPM50H3Q When I plug in the Plasma monitor the LED is on (red) - when I power it up either with a remote or onscreen power button - I hear a click and the TV does not come on, the LED blinks twice and turns off. I have to then unplug from the wall to even get the LED back. Any help is appreciated. Thanks, Vic
  • Anonymous Nov 18, 2008
    Samsung Part Number: BN94-00494U from Partstore.com
Anonymous
Samsung Part Number: BN94-00494U from partstore.com
Posted on Nov 18, 2008
Anonymous
VIC IN CT ,
WHAT PART IS IT THAT YOU BOUGHT ?
Posted on May 17, 2008
Anonymous
I replaced the main power board... got a multimeter from HomeDepot to test where the power was failing. Found the part @ partstrain.com for under $300. If I had taken it to a repair shop it would have cost $300 just to open the back cover & then parts & labor.
Hope this helps.
Posted on Mar 06, 2008
Have same tv HP 42 plasma, red light is on but no image or sound. all I can hear is a click sound when I first plugged it and another one followed few seconds after. what could be the problem?
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If tou see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Dec 03, 2014 | HP PL4260N 42 in. Plasma HDTV
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
The tv was left on and gone off wit a red led showing under the clock on the front of the tv due too the remote being broken we dont know how to put the tv on
On the right side of the tv bazel frame have manual buttons,like a power button,like 2 channels buttons one for up and one for down and a Meneu button.Push the tv manual power button,ur tv should have power and tv will be on.Or try website like Remotes.com to buy a new remote same as ur original tv remote.
Dec 02, 2010 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
TvV will not power on
1. this may be a power supply issue if it is seek qualified help in replacing the power supply unit.
2. Could be a fuse on the power supply unit and also when opening this unit be sure you realize your risk involved seek help from a tech if need be.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Panasonic Viera TH-42PX80U Plasma TV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
[email protected]
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Samsung PPM50H2 50 in. Plasma Television Logo
283 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
