Question about ZTE Cell Phones
My old zte after I factory reset it it wont let me connect to a network
Posted by Clint Douglas Leaver on
Emily Wang
    Sergeant:
  • ZTE Expert
  • 90 Answers
You can follow the steps below to have a try and resolve this:
1. Make sure the computer is connected to WiFi.
2. Ensure Assistant for Android is installed on the device. If not, connect the device with PC via USB cable and MobiKin Assistant for Android app will be installed onto your device automatically.
3. Open the app on the device and scan QR code.
4. Choose the correct computer on the device to get connected. If it doesn't work, you can try to connect it through a USB cable. You can go to here to learn the detailed steps to make your Android device be recognized by the program.
https://www.mobikin.com/android-backup/what-to-do-if-the-device-fails-to-connect-via-wifi.html
Posted on Aug 17, 2018
Johnk Wilson
    Sergeant:
  • ZTE Expert
  • 81 Answers
Here are 4 solutions for your reference.
1. Restart your ZTE and reconnect Wi-fi on it
2. Forget the Wi-fi you are connecting
It is probable that there are something wrong with the Wi-fi which your phone is currently connected to. For example, the password of the network is changed but you are still using the old one. In this case, you can wipe the Wi-fi on your phone and then re-add it manually. The details are as below:
3. Check out the router
As we mentioned above, router plays an important role in mobile phone Wi-fi connection. So it is essential for you to check the running status of the router. If you have no idea whether it works well or not, you can try to restart the router or even reset your router to fix the issue. After that, you can reconnect your device to Wi-fi to see you can hook up to Wi-fi this time.
4. Reset Network Settings on ZTE
Another possibility of Wi-fi connection failure might be Wi-fi caches. It seems that Wi-fi does not create any caches on the device but this thought is wrong. Wi-fi networks produce cached data as well, especially when you connect a bunch of wireless networks on your phone. Hence, you are advised to reset the network settings on your phone to clear these caches.
Posted on Aug 15, 2018
4 Related Answers
Anonymous
SOURCE: code to reset factory settings for zte a201
CAN I PLEASE GET MY PASSWORD TO RESTORE MY FACTORY SETTINGS OF THE ZTE A201.
Posted on Aug 24, 2009
Anonymous
SOURCE: Code to reset factory settings for zte a201
PLZ I WANT THE CODE TO RESET THE PHONE
Posted on Oct 26, 2010
kama bhagat
SOURCE: Zte network not connecting after factory reset.
samsung wave s5253 mic not working
Posted on Aug 14, 2013
barrie kaiser
  • 22 Answers
SOURCE: My ZTE source "cannot establish a reliable
Sometimes in this case the battery may be weak or on its last legs try another known good battery or a new one.
Posted on Nov 19, 2014
How do I bypass google account after reseting the phone on my ZTE Z835
To by bypass this google id on ZTE Z835 you have to hard reset it & remove / wipe all of it`s data/settings. For this you can
  1. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  2. Press the Volume down button to highlight wipe data/factory reset.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
To Network Unlock it 24x7unlockcodes.com is the right place to unlock your zte Z835. You may need this when you are switching your sim card for change your network or visiting abroad. You can get your unlocked permanently by our hassle-free procedure in a competitive price online at your door step!!! Just order us & relax at your home, we e-mailed you once it done.
Use of unlock code for Zte Z835 network unlocking is totally legal. We insured you that our service will not change any feature or behavior of your Zte Z835. The data in your Zte Z835 will also remain protected.
Under circumstances like, If the code will not successfully derived by us or will not work on your Device, we guarantee our customer fully refund of their money.
For Permanent Zte Z835 Sim Network Unlock Pin
https://24x7unlockcodes.com/product/any-zte-unlock-code
For Permanent LG Network Unlock Code
https://24x7unlockcodes.com/brand/lg
For Permanent Motorola Network Unlocking
https://24x7unlockcodes.com/brand/motorola
Best Sim Network Unlock Pin Provider
24x7UnlockCode Network Unlock Code IMEI Unlock Code Unlock Code
Sep 24, 2018 | ZTE Cell Phones
Bought a zte boost max from a person .took it to boost to switch my boost phone to zte and representative acidentially reset phone so now it says need old email address and passwordany way to fix
How to Hard Reset Boost Mobile ZTE MAX 9520 ... - YouTube
? 1:40
https://www.youtube.com/watch?v=SkMDrK5fWSA
May 17, 2014 - Uploaded by HARD RESET KING
Reset Hard Reset for ZTE ZMAX Locked with Google, Screen pattern or PIN - Duration: 1:59. by Klavdio ...
ZTE Boost Max - how to hard reset my phone - HardReset.info
www.hardreset.info/devices/zte/zte-boost-max/
Hard Reset ZTE Boost Max. First method: Turn off your phone. Format ZTE Boost Max; Press and hold Volume Up + Power at the same time for a few seconds.
How to: Factory Reset a BoostMobile ZTE Phone ...
https://raydatroubleshooter.wordpress.com/.../how-to-factory-reset-a-boo...
Jan 05, 2016 | ZTE Cell Phones
My zte has no internet
If factory reset is not working perform hard reset and make sure to back up all the data and do check the network settings first.
Mar 01, 2013 | ZTE Score
Sim network unlock pin for zte-z990
1. Press emergency call in idle mode.
2. input (Star key)983(star key)987(spawn key)it will go to the factory reset interface and customer can reset the handset to Default.
Note:Please do remember to remind the customer this method will delete all the personal information in the phone.
Nov 03, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
Unlock zte z990g
Press emergency call in idle mode .Press *983*987#.This will go to factory reset interface.you can reset your handset to default.
Oct 05, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
Unlock code for zte z990g
Hi if you want to unlock your ZTE Z990 mobile from network lock then visit Mobileunlocksolutions.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .then at last they deliver you code to unlock your mobile.
Aug 20, 2012 | ZTE Cell Phones
Cell Phones Logo
141 people viewed this question
Top ZTE Cell Phones Experts
Dakshinamurthy...
Marvin
Marvin
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
