Question about DISH Network Televison & Video
I have a Jensen JE3215 TV and am having trouble programming my Dish Network remote #21.1 to control the functions of the TV. I have gone through ALL the codes to no avail. Any ideas?
Posted by Kevin Morrison on
john h
    Top Expert:
  • DISH Network Master
  • 23,424 Answers
Notify dish for assistance
Posted on Aug 07, 2018
5 Related Answers
Anonymous
SOURCE: Need Remote Codes for Dish Network DVR
Durabrand tv's have three codes they are 623, 220, 221. one of those codes should fix your problem.
Posted on Apr 16, 2008
Anonymous
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
Posted on May 06, 2008
Jim Franks
  • 374 Answers
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Posted on Nov 11, 2008
Anonymous
  • 64 Answers
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Posted on Nov 25, 2008
Jason Morris
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 14, 2009
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
I have ( Apex digital LD4688 ) I neeed the code. Thank you.
I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
Nov 27, 2010 | DISH Network IR Remote Control
HOW DO I PROGRAM THIS REMOTE FOR DISH NETWORK I HAVE ON MY SONY TV
Hello there!! You may have gotten this resolved, but if not, here are some simple steps. Just follow the link below, and your remote will be working for your tv in no time!!!!
Hope it helps!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Nov 11, 2010 | Jensen JER-822 Remote Control
Having trouble getting my Dish Universal remote to connect to my Insignia 19" flats screen television. I think it is the silver (ES3189) model remote
traceroberso,
I came across your post. Are you still having problems with your DISH Network remote operating your Insignia TV? If you still are, I have 2 codes you can try to see if it will work on your TV. The codes are: 720, 539. The steps to program the remote to the TV are below.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network - Executive Offices
Nov 11, 2010 | DISH Network EZ Remote Remote Control
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
I would like to control my dish network receiver 3100 with my samsung remote
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
May 07, 2010 | DISH Network 32 Ir 137180 Remote 5900 3100...
Remote Problem
Remote codes are programmed into the remote at time of and since the TV was manufactured after the remote it will be unable to have the code as TV manufacturers change codes often. You can try having a 20 or 21 remote sent to you but ensure it will work with your receiver. These remotes are programmable and ar able to learn functions of other remotes. Thanks for using Fix Ya.
Jan 31, 2010 | DISH Network IR Remote Control
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Dec 13, 2007 | Jensen JER-422 Universal Remote Control
Dish Network Remote Code?
My remote dosen't want to listen to me. The light dose show but it's not doing what i say. Whats the matter with my remote?
Sep 02, 2007 | Jensen TS2050J 20" TV
Televison & Video Logo
200 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
