Question about KLH Audio Players & Recorders
KLH E10 subwoofer gain pot shot. Worth fixing?
Posted by Jim Albertson on
4 Related Answers
Duncan
Mike Duncan
  • 219 Answers
SOURCE: Gain pots are shot
If you have the old pots then the value is usually printed on the side of the pot. If there is no number and you have the pot then you can open them up and using a ohm meter take a reading directly off of the carbon film of the pot. Read from one end to the other. I would expect something on the order of 25K (K=thousand) to about 50K. If you can , get the audio taper style of pot, but in a pinch the linear taper will work. The trickiest part will be to get one that is close enough in size and shape to directly replace the original mounting. Good luck. By the way, in extreme cases I've even used fixed resistors (3 or 6 resistors depending on mono or stereo) to replace a pot and then you just choose resistors that will place the volumn at say 2/3 full.
Posted on Jun 30, 2007
Anonymous
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
Anonymous
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
hoytpr
SOURCE: my model 765S KLH powered subwoofer keeps blowing
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Posted on Jan 09, 2011
Tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
on Sep 25, 2009 | KLH ASW10-120 Subwoofer
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Lightning hit the speaker and now it makes a loud buzzing noise. The fuse looks good, but not sure if it is.
It's very likely that lightning has damaged the internal parts of the speaker. You may be able to get it fixed, but it may cost more than the sub is worth.
Oct 19, 2015 | KLH ASW10-120 Subwoofer
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
Nov 13, 2010 | KLH ASW10-120 Subwoofer
Dec 26, 2009 | KLH ASW10-120 Subwoofer
My speaker just rip.. i like to know any subwoofer is ok for replace??
it's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
Dec 12, 2009 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
Loud humming sound from subwoofer
just try leaving it unplugged for a while thats what i did and it fixed it
Sep 21, 2008 | KLH PSW8100-8 Subwoofer
Info
I wrote to KLH and they sent me the schematics for the upper and lower boards. I asked if I could share them, and they gave me permission to post them for use here.
Have fun!
Mar 10, 2008 | KLH ASW10-120 Subwoofer
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
