Question about Durabrand Audio Players & Recorders
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
Posted on May 10, 2008
SOURCE: I need a replacement remote for a Durabrand Home
I found one to purchase online.
Posted on Dec 03, 2009
SOURCE: i need a fuses for my durabrand home theater
Do you mean it blew them again or that it didn't work and the fuse is still intact?
If it blew it again the problem is not the fuses. Instead what you have is a semi-conductor device that has developed a short and that is blowing the fuse. Check any devices in the power supply section, look for signs of damage or heat and also any devices on the heat-sink.
If the fuse did not go and it still doesn't work check the power supply only or the on-off switch.
Posted on May 27, 2011
SOURCE: My durabrand home theater system will not turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 04, 2011
