SOURCE: my phone dect 6.0 uniden rings when someone calls
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
I
hope that will help .
rate if useful please !
SOURCE: I have a Uniden 6.0 DECT cordless phone. Misplaced the manual.
Since you dont list which specifc model you have, I cannot list the specific manual. But here is a link to Uniden's list of manuals, you should be able to find yours here. http://www.uniden.com/index/manuals_results.cfm?cat+1
SOURCE: My answereing machine is coming
hello roger. I am the bearer of bad news for this answering machine. There is no easy fix to this problem as the circuit board is bad. This happens because the solder in the circuit board eventually deteriorates and no longer works properly. Joe
SOURCE: How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
go to menu , select setting s , ring tiome ans increase it
