Question about Furniture
My chair massager does not turn on - Furniture
Posted by susana ramirez on
2 Related Answers
Azrael SRL
  • 11800 Answers
SOURCE: My EMS 9 massage chair
The massaging is done by small motors with eccentric weights attached to the shafts. Those motors are controlled thru a very simple control board that in your case appears to have failed.
To fix the chair you will have to access the board and find out why it has failed - at least a basic experience in electronics is required, to perform the tests on the relays and triacs used to control the motors. If you don't posses this experience then all you can do is to check that the power cable, the remote cable and the motors cables that plug in the board are firmly inserted - for everything else you will have to call a pro.
Posted on Sep 14, 2011
easymassagec
Derek James
SOURCE: What is the difference between a Swedish massage chair and a Shiatsu massage chair?
Swedish massage is common massage therapy that involves long and soft kneading strokes in a rhythmic and light manner. The Swedish massage chairs have basically five moves which are as follows: The effleurage, petrissage, friction, tapotement and vibration.
Shiatsu massage is a Japanese technique which denotes finger pressure. The shiatsu massage chairs integrate erratic rhythmic pressure on the required parts of the body which could also be termed as the acupressure points.
http://www.easymassagechair.com
Posted on Nov 23, 2017
Where can i find the fuse?
What Can Break in a Massage Chair? - Elite Massage Chairs
https://www.elitemassagechairs.com/what-can-break-in-a-massage-chair/
So believe it or not, the most common problems in a massage chair - about 90% of ...but it's not always easy depending on the design of the chair to find the fuse that ...This is the electric motor that moves the footrest up and down in a smooth ...
power outlets fuse location Electric Massaging Chairs ...
www.fixya.com > Forum > Tags > power outlets fuse location
Electric Massaging Chairs power outlets fuse location questions and answers. ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product ...Where can I purchase a plug in outlet chord (power chord) for the osim ...
electrical fuse blown Electric Massaging Chairs Questions ...
www.fixya.com > Forum > Tags > electrical fuse blown
Electric Massaging Chairs electrical fuse blown questions and answers. ... In short does anyone know where I can get a circuit board for this chair? ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product manual: ...
radio ht Electric Massaging Chairs Questions & Answers ...
www.fixya.com > Forum > Tags > radio ht
Electric Massaging Chairs radio ht questions and answers. Ask your radio ht electric massaging chair questions. Get free ... Do you know where I can find fuses?
Amazon.com: Electric Full Body Shiatsu Massage Chair ...
Dec 14, 2015 | Furniture
Where to get neox massage chair parts
Massage chair replacement parts can be found at amazon, click here and take a look: Amazon com massage chair parts. Cheers
Feb 27, 2013 | Furniture
Are there massage chairs that are geared specifically towards one type of massage?
yes, there are massage chairs that are even called ‘Shiatzu Massage Chairs’ or ‘Swedish Massage Chairs’, which obviously specialize in those forms of massage. There are also higher end chairs that offer several settings for different kinds of massage, in case you don’t always want the same technique.
Dec 25, 2012 | Furniture
What is a standard massage chair?
A standard massage chair is a chair that's the patient sits on while getting a massage. These chairs have an ergonomic design. Unlike mechanical massage chairs, they are lightweight and portable.
Sep 09, 2012 | Furniture
How are shiatsu massage chairs?
Hi have a shiatsu massage chair here you can find best shiatsu massage chairs http://bestmassagechairsview.com
May 29, 2012 | Furniture
Can I use an electric massage chair when I'm pregnant?
It should not be a problem to use an electric massage chair whenyou're pregnant. In fact, it's a greatway to relieve all that stress.
Furniture Logo
642 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
