SOURCE: I have a pfaff creative 1471 and it seems like the
Can't believe no one answered you. I would highly suggest you take it in. From my searching around learning about the Pfaff 1471 I was just given. I found it is a very good machine and well worth spending well up to 500 to keep it in good shape. I just had to cut back on the extra I pay on my car payment just to pay the 150.00 tune up on her (ouch). But she runs like a dream now. The machine is so good I didn't even notice she needed it. What you seem to be saying wrong seem to be the most common thing I have read goes wrong with the 1471. I get there is a spring that gets gummed up. It should be replaced/cleaned and regressed by a pro. If its as common as it sounds shouldn't cost more than what I paid.
SOURCE: the shaft on my Baby Lock 1650 sewing machine
You can contact a1sewingmachine.com for the part for your machine. Thanks for contacting FixYa.
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
