Question about Nintendo GameCube Console
Need to repair gamecube ASAP
System fell and now when you put disc in it only shows demo. I think a piece broke where disc belongs. Where can I send it or go to get it repaired. I live in New York.
Posted by Pieces on
Anonymous
  • You don't take care of it.
  • Family member/friend did something to it when it fell down.
  • You use it too much and it overheated and fell down.
Posted on Dec 08, 2007
My gamecube freezes in the middle of a game and says an error has occured, it tells me to check the gamecube manual but i don't have one! PLEASE HELP!
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
  • Aug 03, 2010 | Nintendo GameCube Console
    Pump fell apart - inner piece fell out
    On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
    Jan 05, 2010 | Cycling
    Damn gamecube!!!
    first clean the laser lens
    Jul 24, 2009 | Nintendo GameCube Console
    My gamecube wont work
    Jun 01, 2009 | Nintendo GameCube Console
    I dropped my gamecube and now my controllers arent working
    Odd that would happen. Must have been a really hard crash on the ground.
    Usually the Gamecube can handle more of a beating.
    Though I'd expect the disc drive to go out for the controllers would.
    All I can think of is that the controller ports where knocked out somehow. Perhaps even just the cord that connects the ports to the rest of the system was knocked loose.
    The only solution I can give is to open the Gamecube and see if you or someone can reinsert the wires or resolder them.
    I don't think it could be anything worse than something being forced out of place like that.
    Could also be a severed wire if a piece bashed into it somehow. Though desoldering the old wire(s) and soldering a new one is sometimes easy enough.
    If all else fails you can also find a replacement part.
    These can be a little pricey depending on the site and hard to find so make sure search around a good lot.
    Oh and as for opening the console itself, well, it requires semi-special tools.
    Some security screw screw driver sets have the right shape needed or one close enough.
    You can also find screw drivers sold as "gamecube repair screw driver" at times as well and can be rather cheap to buy.
    They seem impossible to get but they are out there and ya never know when you just happen to have one that'll work.
    I hope this helps out some.
    Good luck with the repairs.
    May 04, 2009 | Sega Sonic Riders for GameCube
    Gamecube Recognizes what game the disc is, but cannot read it
    Make sure its in the right way (image facing up) then close the lid and press power button it should load the game up automatically (dont hold a after switching on the gamecube. if it persists take out the disc wipe it again blow on the gamecube to remove and dust then try switching on the gamecube without the disc it should show the menu, press up and there should be a question mark, insert disc, there it should show the game, press 'A' to confirm, then press start if it persists it is recommended you get it checked out because it could be the case that the disc is badly written like my lego starwars 3 on one of the levels it goes wierd and it spoils it really (i think there is a problem with all starwars games personally). Anyway Hope i helped as much as i could.
    Apr 30, 2009 | Sega Phantasy Star Online: Episode I and...
    My gamecube has problems with reading all my games
    did you check the back of all your discs for scratches thats the problem or gamcubes broken down if you try a new game and it does the exact same thing send your gamecube to nintendo for repair hope this helps.
    Dec 20, 2007 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    35 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Ekse
    Muntejaya Ginting
    Muntejaya Ginting
    Lee Hodgson
    Lee Hodgson
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
