Sajid khattak Posted on Aug 06, 2018
Code error SC545 Ricoh SP210su - Aficio Ricoh Office Equipment & Supplies
Reji Kuriakose
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 20, 2019
Reji Kuriakose
Contributor
Level 1:
Answers
Questions
0
Helped
13454
Points
16
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer
Press C (Red colour centre) button once
Enter 107 (nothing will be shown)
Press the Green (Coping) button for 5 seconds
See the Display -->
Select Engine Maintenance
Select Ok
Select Fuse SC Reset (press down arrow - at down you will find it)
Execute (by Pressing the Down Arrow)
Done
Restart your printer.
Your problem should be solved....
5 Related Answers
Anonymous
  • Posted on Sep 09, 2008
SOURCE: sc545 code
In this case, IT support staff corrected. Not sure what solutions or actions they took.
Everett Lin
  • 990 Answers
  • Posted on Apr 09, 2009
SOURCE: this is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 26, 2009
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Anonymous
  • 29 Answers
  • Posted on Aug 18, 2009
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
joel_baleta
Joel Baleta
  • 155 Answers
  • Posted on Jan 26, 2010
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
6helpful
4answers
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
5helpful
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
1helpful
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
9helpful
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
