Televison & Video Logo
Cruznsac Posted on Aug 05, 2018
I have a logitec harmony remote and am trying to setup a trutech monitor model 008-09-0115 but hadmony does not have info in database is their a similar brand that might work?
I don't have orig remote ....all buttons on side on monitor work but would like to make it a little simpler with remote functions (any would be nice )
5 Related Answers
Anonymous
  • Posted on Jan 18, 2009
SOURCE: Need help with harmony 520 remote
Thank you, this worked.
Anonymous
  • 12 Answers
  • Posted on Apr 15, 2009
SOURCE: Initial Setup Stalls at 0%
reinstall your software and connect in the back of the computer to a usb port directly connected to the motherboard
Anonymous
  • 23 Answers
  • Posted on Dec 11, 2009
SOURCE: my remote for the harmony 550 says welcome to
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
Anonymous
  • Posted on Dec 22, 2009
SOURCE: Need Universal Remote Codes for TruTech
I need a remote for TruTech model DW13TT
Anonymous
  • 101 Answers
  • Posted on Jan 21, 2010
SOURCE: logitech harmony 890 display is blank
this sounds like it is a hardware issue, try contacting Logitech through e-mail from the website www.logitech.com and sending an e-mail in.
try the following before contacting them:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
If this doesnt work, provide them with the following to make sure the process goes as smooth as possible:
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
1helpful
What universal remote works with this blue ray/dvd player?
Try a Harmony remote by logitec. One remote will replace all the remotes you have in your system. Go here for more information: http://www.logitech.com/en-us/harmony-remote
1helpful
I have an alba tele in my children's room, we bought it a year ago. We have missed place the remote control ? So now can't press play on the DVD, is there anyway to get a replacement? My email is-...
Purchase a Logitec Harmony remote. When you set it up, the software asks for the device you intend to control. Enter in your make, and model number. After the remote setup is complete, you should be able to control it.
I would check on the logitec website before you purchase to make sure your device is supported before making the purchase. But they support just about anything under the sun.
I got bush TV cant do anythink cuz havent got romote
I got bush TV cant get off device cuz havent got remite
I would check on the logitec website (logitec.com) before you purchase to make sure your device is supported before making the purchase. But they support just about anything under the sun.
Samsung UN46D6300 TV not in Logitec Harmony 700 remote database. Need IR code/s to enable controls (especially TV input source selection). Learning mode was only partially successful for power, volume...
When i went into the Harmony software, your TV did come up. If these codes aren't working try a different model Samsung (like UN46D6000). All new Samsungs use the same code set. If this still doesn't help, go to "Devices"->"Settings"->"Adjust Inputs"->"Method 3". Follow the directions from there. Something else that may help is Samsung calls it the "Source" button, Logitech calls it "Input x".
Need to reprogram remote
Quick fix try and leave batteries out for a day to see if it looses all memory. Also try uninstalling software removing all user settings, then reinstall and try again.
1helpful
Harmony 670 wont work with vizio
Went through the IR learn in the setup and was able create functionality. Not sure why original setup did not work cause the tv model is in the database.
2answers
No remote for T2000D 20 inch TV. Bought a Trutech
I have a Logitech Harmony 550 that does the job very well.
I have a Citizen TV, model # JCTV2704X. The remote control does not operate and I'd like to locate a replacement. Thanks Bill ([email protected])
I have The Logitech Harmony One remote, and would recommend it to anyone. It's easy to setup, use, and has built-in help. Logitech has a vast database of products these remotes work with.
2helpful
2answers
Denon AVR-4802 multi-zone problem.
I had the same questions and still can't believe there isn't more information on the topic. It's crazy how much marketing Denon devotes to their Multi-Zone features yet offers very little reference materials on the actual set up. I guess most customers don't use the fearture? Here you go:
-The Multi-Zone on the Denon 4802 is analog only. If you are running digital coax or fiber you will have to run a second line that's analog (eg RCA red/white) from the source to the Denon in order for the signal to to make it to the Zone 2 speakers (regardless if it's Pre-Amp out or direct connect to the Zone 2 speakers from the multi/SB speaker outs. Regarding the Harmony question, I had the same problem with my Harmony 880 and wasn't able to find an answer after multiple searches. Luckily I figured it out when I deleted the receiver from the Logitec device list and started over. Connect the remote to your computer, launch the Logitec Harmony Remote Software, click the Devices tab, hit the Add Device, pick the device type & manufacturer from the drop down list, enter "AVR-4802" under Model and finally hit the Next button in the lower right corner of the UI. The next page solves the Harmony Zone 2 control problem. You will see a message "To use your device in additional zones/rooms, click the checkbox...." Make sure Room 2 is checked (mine was not), update the remote and you're done. The Harmony Device menu you will now contain a second receiver icon called "receiver 2." Hit "device" on the Harmony, choose "receiver 2" and you will gain control over Zone 2 including volume.
Steve
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
