Question about Crate Music
I NEED THE SPECS FOR THE CRATE GT-200 AMP MAIN TRANSFORMER
Posted by DEWEY GREEN on
  • Crate Master
  • 18,520 Answers
Contact the Crate Service Department at 1-800-738-7563 or 314-569-0141 (8:30am-5:00pm central time, Monday-Friday) to order any parts and/or schematics.
Posted on Aug 05, 2018
1 Related Answer
PolyrhythmFX
PolyrhythmFX
  • 109 Answers
SOURCE: crate gt 30 amp reverb wire loose. whrer does it
If its the input reverb tank wire or output reverb tank wire just reconnect it (if the amp has a reverb tank).
Posted on Jun 20, 2009
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Feb 21, 2018 | Crate Music
Have a Crate V50-112.Have had it for 1 year. Replaced tubes 2 weeks ago, turned amp on tonight, started to play, amp went dead. Checked fuses, they're good. Any ideas?
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Feb 02, 2010 | Crate Music
I have a Crate GT 15, not getting anything to the speaker when I plug in.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Jan 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 that hasn't been used in a long time. I destress and sing. Anyoo it has a power issue. Light is flashing on then goes off. I can't find a manual. Can anyone assist me please?
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
May 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, [email protected]
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
Crate gt 30 amp reverb wire loose. whrer does it connect?
Feb 27, 2009 | Crate Music
Music Logo
139 people viewed this question
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
