Question about Whirlpool Home
Whirlpool espree 6060 pump will not start but can her the air click the switch at the pump. Gfci is working.
Bad start up capacitor if voltage to motor or bad motor
1 Related Answer
Anonymous
  • 81 Answers
SOURCE: Our Jacuzzi Espree 6060 corner whirlpool stopped
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
Posted on Jun 03, 2010
I have a espree 536 whirlpool jacuzzi tub the on and off botton doesnt work what could be the problem
Check under skirt and see if gfci receptacle has tripped. If it has you should call electrician.
Nov 03, 2017 | Jacuzzi Home
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Whirlpool tub pump not working
Have you checked the GFCI for the pump?
Check the controls, if it is air button operated inspect the air button, vinyl tubing and the air switch in the motor. If you have electronic controls, there isn't a good way for a home owner to test it.
  • Is pump getting power, if yes...
  • Are controls working? If yes it is the motor, they are small and cheaply made so it is likely. If no check or change the controls/switches.
Nov 28, 2012 | Home
Jets in whirlpool tub not working
If its on a GFCI circuit reset switch.
Air button activation - check for loose air tube connections or bad air button.
Electronic control - contact a spa technician for diagnostics.
If the error is not electricity to the pump or the button(s) controlling the pump - it is likely a bad pump.
Jan 17, 2012 | Whirlpool Home
Jets will not come on after filling and pushing on switch
There are several things to check.
the first and most likely is that you have a Ground Fault Circuit Interrupter (GFCI) that is tripped.
It is required by code to have any whirlpool tub, spa, or similar equipment GFCI protected. on a whirlpool tub, a good electrician will place the GFCI device within sight of the tub, in the bathroom. it looks like the same GFCI receptacles you have on the countertop, but without holes to plug things in. a lesser electrician will place a GFCI receptacle inside the service access underneath the tub. (this can be a hatch in the side of the tub, or a cabinet door in on a wall adjoining the room) a bad electrician has been known to place it in a completely different room, or under the floor, with the power cord of the tub passed through the a hole in the floor to plug in. find this, and press the reset button. if it solves your problem, great. if not, go to step 2 (also, occasionally, the GFCI device is a GFCI breaker inside the breaker panel - check to make sure the breaker is turned on and not tripped, as well)
If you reset the GFCI and it immediately trips again, there may be a problem with the pump motor. find the access hatch (if you haven't already) and unplug the tub. try the reset again. if it holds now, it is the pump. if not, it is either a failed GFCI (have it replaced) or a ground wire in contact with a neutral wire. (fixed by moving the ground)
if the GFCI resets, or will not reset (newer GFCIs have an interlock feature that prevents them from resetting if they don't like the flavor of the incoming power) and there is still no power to the pump (use a plug tester, or plug a lamp, or radio in to test and make sure there is power to the spa tub), and you have confirmed that the breaker is on, there may be a switch that is off, (the same electrician who put the GFCI device in a walk-in closet across the hall, also had a switch that turned the whole thing off) or there may be a wiring problem somewhere. at this point, it might be worth your while to bring in an electrician to trace down the problem. - you would have to check each point in the circuit to find where there is a wire disconnected or broken.
If there is no problem with the electricity to the tub, then you have either a switch problem or a motor problem. the motor problem is unlikely, as it usually results in electrical symptoms, as well. the switch is an air switch. the button on the tub is an air plunger, that pumps air into a tube, and pushes another plunger in the switch that turns the pump on and off. the plunger can stop pushing air (unlikely, but possible) the tube can come loose, or the switch can stop working. the first two are easily user-repairable. the last may take an authorized service professional, depending on the design of the pump.
If you have acces to the pump and switch please let me know I will walk you through what to look at there to fix if the plug is good.
good luck with this - hopefully it is just a GFCI.
Mar 13, 2011 | Whirlpool Home
Our Jacuzzi Espree 6060 corner whirlpool stopped working after about 15 months of light use. I called the company and they had me order an air switch. Our motor does nothing. No clicking. GFI is working. I...
May 30, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
My jacuzzie motor just clicks and won't turn on.
Look behind the tub cover, it should have one. You should be looking for a GFCI it sounds like. These are the outlet that you generally have in your kitchen. They have a reset button and it just sounds like it needs to be reset.
Aug 02, 2009 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
