Back of player/recorder says "MPC880 1GB. There's also an 880AL printed. Has a lock button on one side and on other side (from left to right) M, +, -, , >, Fast Forward?
SOURCE: locked coby mp3 player without manual
There should be a lock/unlock button on the opposite side of your mp3 player other buttons. Slide the button to the left, and it should unlock. I hope this helps.
SOURCE: Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it can charge
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
SOURCE: Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
