Question about Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 -
Vizio e601i-a3 turns on and the led back lights flash on and show the "V" loading screen then the screen goes dark.
Posted by Greg Brundage on
5 Related Answers
SOURCE: Vizio 60" E601i-A3 smart LED 120hz 1080p BUI is not powering on after power surge. Any suggestions on how to repair, as it's being paid off still through Aarons, and pretty sure they won't cover damag
Most probably the fuse 'T4A H / 250 V AC' on the power supply board or capacitor/s thereon would have gone off. Either you have to change those dead parts or replace the power supply board with a new one costing around $49.41
Your Power Supply Board shown given below:
Posted on Mar 28, 2015
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: Need to know replacement parts for vizio E601i-A3. It took a power surge from Lightening strike. Turns on but after 30 sec, squeals.
The squeal is likely to be a leaking capacitor find the one leaking and replace it
Posted on Jul 05, 2016
richie46
  • 12962 Answers
SOURCE: I have in a Vizio Model Number E601i-A3 that lighting got. If I replace the power supply board, main/input board, & the t-con board, should that fix it or am I missing something? Help is appreciated!
To get help need to know exactly what the symptoms are so that wrong boards do not get replaced. Now doesn't that make sense?
Posted on Aug 21, 2016
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I have a Vizio 60" E601i-A3 tv. The sound works but the picture is gone. If you shine a light on the tv, you can see a very faint picture. What part will fix this issue?
The screen back light is burnt out or the power supply to it.
Posted on Sep 06, 2016
gopakumarg43
  • 76823 Answers
SOURCE: I have a Vizio e601i-a3 TV which powers on and shows vizio symbol fine then The screen starts flickering and power to the tv goes off after about 1-3 mins. Any suggestions on how. I can fix the Tv?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Oct 12, 2016
Model e601i-a3 TV. On the left side it's dim (flickers) and on the right side it's very dim or dark. What's wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis.
https://elektrotricks.blogspot.com/
If my LED tv is dark, does that really mean that ALL led strips went bad at the same time? Or is it likely something else?
Hi Markus Alison, with only one LED that burns, it is enough so that the back lighting does not turn on
To make a correct repair, I advise you to replace all the LED strips, to prevent the failure from repeating in a short time
Hola Markus Alison, con solo un LED que se queme, es suficiente para que la iluminacion trasera no encienda
para hacer una correcta reparacion, te aconsejo reemplazar la totalidad de las tiras de LEDs, para evitar que la falla se repita en poco tiempo
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
TV turns on, lights up, but no menu, logo or any other picture. There is sound though. Wondering what board to replace. thanks
1helpful
How can I remove rear panel?
http://electro-medical.blogspot.com/
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
1helpful
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Open Questions:
See all Vizio E601I-A3 60-inch Class Razor LED HDTV - Questions
Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
