Watches Logo
Mahesh Chavan Posted on Aug 04, 2018
How to set time in casio wrist watch model 1071
Collins Jordan
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Aug 14, 2018
Collins Jordan
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
1805
Points
59
5 Related Answers
Anonymous
  • 417 Answers
  • Posted on Jul 05, 2008
SOURCE: Casio WR200M Watch.
you need to pull the pin out the thing take turns on the watch don't come right out tho one like 1mm
Anonymous
  • 4 Answers
  • Posted on Mar 24, 2009
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 31, 2009
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Anonymous
  • Posted on May 07, 2009
SOURCE: can't set the time on my casio wrist watch
Press button A (top left) and hold for two seconds. The watch should then receive a time signal - you shouldn't have to set the time on it at all.
Anonymous
  • 2501 Answers
  • Posted on Mar 16, 2010
SOURCE: setting time on a casio sport watch
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Testimonial: "Qujck and easy answer!"
Hey, I recently bought a Casio F-91W but it was supplied without a user manual so basically I'm having problems setting the date, time, etc. I have been onto the Casio website to try and download a...
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
How do you set the time and date on the casio g-shock model 2310
you can get instructions from the Casio web site.
watches;
Accept terms
How do you set the analog and digital time on the casio aw-s90 wrist watch?
you can get
watches;
Accept terms
1helpful
I need to set the analogue time on my casio g shock wrist watch
browse through my tips and you will find link for all Casio watch manual downloads.
8helpful
2answers
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
2helpful
Can't set the time on my casio wrist watch
2answers
Casio WS300B-1BV Wrist Watch
Punch in the 4 digit module number found on the back of the case.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
