This is a craftsman 8000 watt generator.
First, I'm not a Craftsman representative.
* Check your warranty. Call for support
* Contact; https://www.sears.com/en_us/customer-service.html
* Note; Craftsman bought by Lowe's try them for assistance.
*** The following is for information only.***
* Manual (old); https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0806841.pdf
* Throttle adjust; https://www.youtube.com/watch?v=GWFMbOpoKvI
* Contact Sears or Lowe's for advice
* Note; your local "Small engine repair" shop may service these generators.
Aloha, ukeboy57
Additional info;
* Forum; https://www.smokstak.com/forum/showthread.php?t=134772
* Chicago Gen voltage adjust; https://www.youtube.com/watch?v=bjHgH7k-Hu0
* 5600 Sears customer review; https://www.youtube.com/watch?v=Ljvpwcuds1Q
* Gernerac Leaking Carb; https://www.youtube.com/watch?v=K6sng5-vTHs
* Govenor repair; https://www.youtube.com/watch?v=TR1CfvRNni4
* no electric output; https://www.youtube.com/watch?v=Ti9d0vJLA1s
SOURCE: auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
SOURCE: High voltage low cycles
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
SOURCE: use a 7500 watt transfer switch with a 8000 watt
There is no problem to use it if the load to be transferred is under 7500 W.
Even a load of 8000 W may be handled for a short time, but if the protection of the switch is adjusted at 7500 W (the respective current), it may drop after some time.
SOURCE: Briggs and stratton 8000 watts
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
