Question about Maytag Refrigerators
SOURCE: Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Posted on Jul 20, 2007
SOURCE: GE GSS 22KG SIDE BY SIDE REFRIGERATOR 6 YEARS OLD
The codensor fan is not running. I have the same problem. I had the fan replaced a year ago for the same problem, so I can't tbelieve it's the fan. I am guessing something on the circuit board is not letting the fan kick on. I don't have a definite answer yet, but the fan not running is the main issue you are having.
Posted on Sep 30, 2008
SOURCE: freezer has bad smell, cleaned entire fridge and
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website.
on
www.repairclinic.com
Posted on Mar 31, 2009
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
Aug 21, 2011 | Maytag MZD2766GES Side by Side...
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Aug 04, 2008 | Freezers
Mar 16, 2008 | Refrigerators
Jul 11, 2007 | Maytag MZD2766GES Side by Side...
Jun 18, 2007 | Maytag MTF2195AE Top Freezer Refrigerator
93 people viewed this question
