Question about Hitachi Televison & Video
Where is the reset button on the Hitachi plasma
I get no sync/signal on my tv and it doesn't have a reset button
Posted by Anita Shataka on
    Top Expert:
  • Hitachi Master
  • 76,407 Answers
There is no sych special button with modern TVs. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the sites linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/ http://electro-medical.blogspot.com//
Posted on Aug 04, 2018
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: No Display
for the HD15 connection you need to set your TV to PC mode
the only thing I can think that you may be doing wrong is that you need to "ACTIVATE" the external outputs on the laptop,as they are not on by default.
To switch video output mode  LCD / CRT (monitor/PC mode) /TV mode plus some dual modes LCD + CRT / LCD + TV
I have found that the overlays used for video playback do not work in the dual modes,  (and I have found that CRT monitor mode is best for connecting to a large TV)
so switch your TV to PC input,  connect your HD15 cable and SWITCH output mode on your laptop (usually Fn F5) press until you get an output,
you will also need to connect audio, so get a phono -> 3.5mm jack plug and plug that in also, and you are ready to rock and roll
Posted on Oct 11, 2007
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: my Hitachi 1080, 42 inch plasma Tv purchased in
The Main digital board has problem, part# UX28023 (for P42H401, not P42H401A) , approx $170.
Posted on Apr 25, 2010
Anonymous
  • 9 Answers
SOURCE: When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Posted on Aug 20, 2010
peter rady
  • 144 Answers
SOURCE: 37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Posted on Nov 10, 2010
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: i have a Hitachi hi
Good day!!!! Please get the remote and press the menu button after that select and choose the default or factory settings then enter.... After that power off all devices(set top box,dvd,TV) and wait atleast 5 minutes then power it ON again... And see what happen... Thanks for using fixya...
Posted on Sep 19, 2011
What's your problem?
First, make sure this isn't coming from your signal source; these items are not listed in any of the functions described in the manual for your monitor.
If disconnecting, changing or turning off your signal source doesn't get rid of the control item display, try resetting the monitor (maybe the display has some extra firmware features not in the documentation):
  1. Press the Menu button on the side of the monitor.
  2. From the On-Screen Display, navigate to the Setup&Reset menu using the arrow buttons, then press the Source/Select button.
  3. Navigate to "Reset" and select it.
This should restore everything to the factory default setting and get the TV/monitor out of whatever mode it's in.
Dec 03, 2011 | Samsung 23IN Led 1920X1080 5M1 PX2370 Dvi...
Tip
Wii doesn't sync remotes - Here is the fix!
If you are having problems syncing your Wii Remote (or Balance Board) to your Wii, follow these steps to reset all synchronized devices.
In many cases this will clear up the issue.
1. First you will need to check a few things, just to make sure what the actual problem is.
- Check to see that all cords are properly plugged in.
- Make sure the sensor bar is properly center above or below your TV set.
- Make sure that nothing is blocking the signal to the sensor bar.
- Make sure that the batteries in the remote are in good working order.
- Make sure that there are no wireless devices close by that might be interfering with the signal.
2. If after all this the remote is still not working then it probably needs to be re-synced.
3. Turn off and unplug your Wii console for five minutes.
4. Plug your Wii back in and power it on.
5. When you see the the Health and Saftey screen open the small flap on the front of the Wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
6. Remove the battery cover from the Wii remote, inside you will see another red button.
7. Press and release the red button on the Wii Console.
8. Press the red button inside the Wii remote and then hit the A Button on the Wii Remote.
9. The remote will stop blinking and it should now be synced.
on May 13, 2010 | Video Game Consoles & Games
Tip
Reset synced devices on your Wii
on Apr 09, 2010 | Video Game Consoles & Games
It saying .. No Sync what does that mean?
No Sync indicates that the input signal doesn't match the type of signal that the TV can read. A digital source going to an analog input could cause the issue.
What is your source for the signal?
If you are using the DVI connection on the TV to connect to a computer, try using the VGA input instead. Unfortunately not all TVs can interpret the computer's digital signal. (It is different than the digital signal from a set top box.)
The manual for the TV is available from the product site: http://insigniaproducts.com/products/televisions/IS-LCDTV32.html . The direct link to the manual is: http://insigniaproducts.com/cms/documents/IS-LCDTV32%20UM%20EN_SP_FR.pdf .
Please add a comment with your source and I will offer additional suggestions for solving the error.
I hope this helps.
Aug 02, 2011 | Insignia IS-LCDTV32 32 in. Television
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
My Wii remote wont work how do i reset it?
No sync no signal
Tries tv and those pay boxes unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Those pay boxes,now will be rebooting and upgrading it softwares.The incomming broadcasting signal sync problems should be solved,if still have no sync signal flashing,than 90-95% those pay boxes have a problems.Call ur cables providers exchange the reciever box.
Mar 01, 2011 | Hitachi P50H401 50 in. Plasma HDTV
The television CT-27G5 is not recognizing the IR from the remote. I have tested the remote and it is outputing a signal. Is there a reset procedure for the television and remote to put them back in sync?
No reset for that. Most likely the remote sensor inside the tv has gone bad. It is at the front of the main PCB beside the front panel buttons. check www.encompassparts.com for availability. Thanks for using fixya.
Feb 20, 2010 | Panasonic CT-27G5 27" TV
It wont appear on the tv or pick up the controller signals
Make sur eth controllers are sync to the xbobx in question. Press the little white circular button on the 360 and the one on the top of the 360 contoller (between the shoulder buttons).
Also make sure you have all the cables connected to the 360 and tv correctly, and make sure your tv is on the right channel. If this doesnt help then google for the 360 video reset code, which will reset your consoles display settings to default
Jul 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 - While setting up in menu the TV went black and msg. No Sync. Signal
First, make sure you select either TV or HDTV selector on the Audio Video Cable that came with the XBOX. Second, if you chose TV plug the Audio/Video Cable connectot that are red, white , and yellow in color to your TV. Now see if you can see the Start up on the XBOX360.
If you still dont get anything, try plugging it on another television and see if that fixes your problem.
Dec 09, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
288 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
