Question about DeLonghi Kitchen Appliances - Others
My delonghi deep fryer randomly turns off while in use. It is only 3 weeks old. Any idea as to why?
Posted by Cecile Keyes on
I have a Roto-fryer DeLonghi, but i have never used. I don't have the manual. I just want to know how to fry frozen potatoes.
Hi there. Try a frying 350 grams potato fries at 190C temperature for 6 to 7 minutes.
Regards.
Aug 17, 2013 | DeLonghi Roto Deep Fryer
Delonghi deep fryer D14527DZ
Hi there.
You can download Owner's Manual for your fryer at the Cutomer care tab on http://www.delonghiusa.com
Regards.
Nov 26, 2011 | DeLonghi D14527DZ Dual Zone Deep Fryer
D14527DZ Delonghi deep fryer
Hi there.
You can download Owner's Manual for your fryer on the Customer Care tab of http://www.delonghiusa.com.
Regards.
Delonghi deep fryer basket replacement
Hi there.
You will be able to find the nearest authorized parts and service dealer on your area by visiting http://www.delonghiusa.com
Regards.
Nov 24, 2011 | DeLonghi D650UX Cool Touch Deluxe Deep...
Delonghi 895ux parts. I like to have basket
Try to visit http://www.delonghiusa.com, you can check there the nearest authorized parts area on your area.
May 24, 2011 | DeLonghi D895UX Cool Touch Roto Deep Fryer
I need a instruction manual for a de longhi roto fryer
Hi there.
You can get Owner's Manual of your Roto Fryer at the Kitchen Appliances page of http://www.delonghi.com
Regards.
Feb 26, 2011 | DeLonghi Roto Fryer F2872 Deep Fryer
What tyoe of oil do you use
What ever cooking oil you prefer!
Sep 13, 2009 | DeLonghi D455DZ Deep Fryer
Model D690UX Delonghi deep fryer
Well I did solve my own dilemma. You have to unscrew the bottom black bolt in the bottom center of the unit. the open up the front panel to reveal a tiny screw just below the top center of the front panel. Remove it. Be very careful and remove the front panel. Pull lightly up on the inner black pot to reveal the clamp that holds the old drainage tube. Using a needle nose wrench, squeeze the clamp together to release the old tube and the clamp. Add new drainage tube inside the clamp and do the reverse. Make sure when you put the front panel back on, the open button's bottom part is inside a little **** or it will not work (it will fall out when you take front panel off). Make sure the little lamp is inside the red ON button.
Et Voila.....all fixed
Sep 21, 2008 | DeLonghi D690UX Cool Touch Deluxe Deep...
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Kitchen Appliances - Others Logo
Top DeLonghi Kitchen Appliances - Others Experts
Paul Bade
Gerry Harvey
Gerry Harvey
ADMIN Canada
ADMIN Canada
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
