Ovens Logo
A
Anonymous Posted on Aug 03, 2018
Hello evrey one How to solve error 2 in cmp rational oven
Mark Cheong
Level 3:
Master:
  • Master 791 Answers
  • Posted on Aug 03, 2018
Mark Cheong
Master
Level 3:
Master:
Answers
791
Questions
0
Helped
475622
Points
2475
First, I'm not a Rational representative.
* This is a Pro oven. Check your warranty. Call your vendor for support.
* Technical support; Tel. 866-891-3528
* Cooking support; Tel; 866-306-2433
* Info; https://www.rational-online.com/portalcontent/club/fs4c/media/files/scc_since_09_2016/brochures/cmp/80.21.517_USA_CombiMaster_Plus_Letter_WA54~1.pdf
* Manual (check page 104);https://www.rational-online.com/portalcontent/club/fs4c/media/files/scc_since_09_2016/handbuecher/manual_cmp/80.02.382_Bedienungsanleitung_CMP_en_uk.pdf
Aloha, ukeboy57
1 Related Answer
k14cks
Marc Donnelly
  • 20 Answers
  • Posted on Feb 28, 2017
SOURCE: Hi I have a combi rational oven shows error 10 . What should I do? The oven didn't do cleaning and has error then service 10 appeared. Thanks
Service 10 is usually caused by a blocked or defective steam generator emptying pump.
Replace the pump or clear out any scale buildup.
Once the problem is corrected you must do an automatic drain to clear the error.
My rational will not turn on at all
Examine the oven's control panel to identify any error codes or displayed indicators.
Sep 04, 2023 • Ovens
Rational CombiMaster Plus System. Good evening, I have a problem with the oven that I have, which is the appearance of E17, and the oven is off. Please help, thank you.
Steam Generator Issue. Call for service, you can't fix these yourself as they are fully computer controlled. Maintaining them is a cost of doing business.
RATIONAL COMBI MASTER PLUS'SERVICE ERROR CODE'S
thehanadvisor.com https://www.thehanadvisor.com > ... > RATIONALCM
Each code will tell you what's wrong with the oven, allowing you to tackle the issue quicker. NOTE: PLEASE SUBSCRIBE E MAIL AND YOU-TUBE CHANNEL. OPEn / H2o.
more here
https://www.google.com/search?q=rational+combimaster+error+code+E17
Manual
https://www.rational-online.com/media/downloads/en-gb/manuals/rational-original-operation-manual-cmp-en-gb.pdf
May 28, 2023 • Ovens
Rational Combi Steamer. What does error code 39 mean?
Page 105 of the manual.
Cooking cabinet temperature selector switch defective. - Notify customer service!
https://www.rational-online.com/media/downloads/en-us/manuals/80-02-406-bedienungsanleitung-cmp-en-usa.pdf
Jan 15, 2021 • Combi Ovens
Rational Combimaster Plus. Why is it indicating E 34?
So I found the service manual for this model.
The list of codes is on page 105. Code E34 is simply listed as contact customer service. Which is not really all that helpful in diagnosing the problem. Have you tried to reset the oven? Disconnect the power cord for 2-3 minutes and trying again? If this doesn't work, given the general code, you should call the customer service number in the manual.
Hope this helps.
Sep 22, 2020 • Ovens
Why combi oven error code 32
If it is a Rational CM or CMP gas oven, then there is a problem with the ignition module.
Feb 03, 2017 • Combi Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
