Question about Photography
Is there a way to lock the tilt on the tripod?
Posted by Ray Pellecchia on
Mark
    New Friend:
  • 87 Answers
If its a pan and tilt tripod the rotate the arm sticking out to lock the tilt.
Posted on Apr 07, 2019
2 Related Answers
gemmy23
Joy Shannon
  • 346 Answers
SOURCE: WE NEED A NEW BAS PLATE ANGLE/TILT LOCKING KNOB.
Here is a home page for the vanguard company. Try contacting customer support to find those parts. Good luck...hope this helps.
http://www.vanguardworld.com/gfa/index.php
Posted on Jul 11, 2009
MIke
  • 685 Answers
SOURCE: Ineed a tilt head for vivitar 914 tripod
Because of the age of the tripod, and the fact that Vivitar no longer sells or supports tripods, I think you would be better served if you bought a new tripod. Slik and Manfrotto are two that will offer you a great price, durability and in the case of the Manfrotto, parts available from a wide range of sources including the USA distributor: www.bogenimaging.us you can see tripod and parts at www.BogenTripodParts.com Otherwise you could try ebay or craigs list to find the same model and use it for parts.
Posted on Jan 01, 2010
I need a tripod head locking handle. This is the handle that maintains the vertical orientation of the tripod head.
Various makes of tripod head use different methods of attaching the pan and tilt handle. Try an Ebay search for spares for your particular make and model.
Mar 02, 2016 | Photography
Can anyone service/repairSACHTLER VIDEO 18P - TRIPOD
time to buy a new tripod, the repair will cost more than its worth.
Apr 14, 2017 | Sachtler Video 18 P Carbon Fiber Complete...
I have a Samsonite tripod with a quick release plate. Is it possible to get another head? one that has a screw so that cameras can be threaded onto it?
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod.
Sep 02, 2010 | Samsonite 54" PhotoVideo Tripod w3Way Pan ...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
What does the round wheel at the top of the tripod do??
are you refering to the "camera attachment" screw or a "tilt" function? : you may have 2 tilting options;1 up/down & 1 for tilting the camera sideways.
Oct 12, 2009 | Ambico 67" TRIPOD
Jul 11, 2009 | Nikon 847 Tripod
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
My Oconner 30 fluid head tilt won't lock, it drifts. How can I fix it?
http://www.bealecorner.com/fx1/OConnor30/index.htm
try looking at this, hope it helps - an attempted repair
Mar 13, 2008 | Oconnor 25L Tripod
Photography Logo
Top Photography Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
