If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Posted on Aug 01, 2018
SOURCE: how do i go from
can I run my sears shop vac without the paper bag, for dry pickup?
Posted on May 02, 2009
SOURCE: I need a manual for a Rigid 5 gal shop vac or a
open it up. the manual is inside.
Posted on Mar 06, 2010
SOURCE: I was using my Rigid WD09450 shop vac and the
I need instruction manual asap
Posted on Jun 28, 2010
SOURCE: weak suction shop vac
Is the tank filled completely with dirt? When was the filter last replaced or cleaned?
Posted on May 16, 2012
click this link for video help
http://www.ehow.co.uk/videos-on_4811_care-portable-shop-vac.html
Posted on Mar 01, 2013
Apr 30, 2016 | Filter Vacuums
Mar 18, 2015 | Shop Vac Vacuums
Sep 30, 2013 | Shop Vac Vacuums
Aug 19, 2013 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Nov 03, 2012 | Vacuums
Sep 06, 2012 | Shop Vac Vacuums
Feb 01, 2010 | Vacuums
Nov 12, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Jul 26, 2019 | Shop Vac Vacuums
Dec 15, 2018 | Shop Vac Vacuums
174 people viewed this question
