Garden Logo
L
Lucille Dolan Posted on Aug 01, 2018
Need a manual for xtreme kleen pressure washer model #XTE1650.
1helpful
8answers
Instruction manual
Check this link if that your user manual
http://www.allbrands.com/misc_files/pdfs/eu430SeriesGuide.pdf
Hope that helps........
Xtreme pressure washer keeps cutting out.
you have to be more specific in your questions. Is this a gas or electric machine? What happens when your machine fails? Does it spray fine for awhile and then cut out? Does it cut out when you turn it on? Give us symptoms .
May 07, 2014 • Garden
Challenge xtreme 2000w pressure washer manual
Hi I have a challenge extreme 2500w pressure washer. it's tree years old , hardly used. I have come to set it up, but seem to have no power or start up after switching it on. any advice would be greatful?
Jul 01, 2012 • Garden
Fix soap dispenser on xtreme dw-1840 bv pressure washer
it will only draw soap when your using the large fitting they don't draw with the high pressure nozzles
Mar 22, 2012 • Garden
2helpful
3answers
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
User Manual
Eureka > 2971AV EZ Kleen Bagless Upright Vacuum is the exact model of your vacuum, right..?
Ok. i'll find again the manual (english)
i will let you know..
Regards,'
micro
Top Garden Experts
Jay Finke
Jay Finke
john h
