Question about HP DeskJet Office Equipment & Supplies
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
SOURCE: hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Posted on Feb 22, 2009
SOURCE: the printer acts like it is printing, but doesnt actually print
1. Clean the scanner/copier glass and white scan backing on the inside of the top lid with glass cleaner. If there is any foreign material on the glass or white scan backing, the scanner will include it as part of the image resulting in extra pages.
OR FOLLOW THESE STEPS
This normally occurs because one of the ink cartridges is low on ink. To fix this, do the following:
Replace any ink cartridge that is low on ink.
Posted on Jun 16, 2009
SOURCE: HP Deskjet F4200, prints blank page
I went into print settings after failing the diagnostics.
Printing normally would just feed the paper through with no ink.
I set the settings to specifically "Fast Draft" and adjusted
minor things like paper to A4 and color to grayscale for the
print job at hand.
Bingo!
Posted on Dec 30, 2009
SOURCE: My HP Deskjet F380 will
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Posted on Jul 12, 2011
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
Aug 30, 2011 | HP Deskjet 1120c InkJet Printer
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
Jul 11, 2009 | HP Deskjet D1341 InkJet Printer
Mar 06, 2009 | HP DeskJet 1220c InkJet Printer
Feb 23, 2009 | HP Deskjet 1120c InkJet Printer
Jan 01, 2009 | HP PhotoSmart 7150 InkJet Printer
Sep 24, 2008 | HP DeskJet 670c InkJet Printer
Dec 30, 2020 | HP LaserJet 1320 Printer
63 people viewed this question
