Question about LaCie Computers & Internet
I have an older Lacie 250gb USB 2.0 hard drive and can not read my photos files on windows 7. How can I open/retrieve my old photos?
Posted by Daniel Stortz on
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: shut down
Email me at : [email protected] and i will send instructions how to repair it
Posted on Jan 27, 2008
motaro
Obiora Micheal
  • 449 Answers
SOURCE: 160 GB Lacie external drive is not reading on my laptop.
i suggest you buy laptop adapter and connect it to a PC so that you can view your file from My computer.note:the computer will see it as drive D
Posted on Feb 05, 2008
Anonymous
  • 91 Answers
SOURCE: Hello, I have a LaCie
All brand-new hard drives are sold unformatted and thus don't show up in Windows until they've gone through the formatting process. To get up and running, connect the drive, boot your PC, and at the Windows desktop right-click the My Computer icon and select Manage. Click Disk Management in the left-hand tree, and every drive connected to your system will show up. Simply right-click your new drive and select New Partition. Then follow the steps to get your drive up and running.
Posted on Jan 03, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Anonymous
SOURCE: HELP! retrieving files from corrupted drive
he should keep the hard drive in the freezer for one day
Posted on Apr 24, 2009
Can I retrieve info,documents etc. from these old bkf. files on my simpletech 160gb usb 2.0 portable drive
The BKF file is only a reference to allow the XP os to know what program opens which file. It doesn't contain photos or music or documents.
Jul 09, 2013 | Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
Can an older Lacie drive (2005?) work with an HP tablet?
The native file system for Macs is HFS. If the drive was originally used with a Mac, the current file system on the drive is HFS. Windows uses NTFS and is not compatible with HFS; which is why Windows doesn't recognize the drive as valid.
You can download a data retrieval tool called MacDrive that will give Windows the ability to speak Mac. There is a free trial available and it should be able to help you grab the files off of the drive.
Aug 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
231 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
