Question about Ovens
I am trying to find the model number of a chef wall oven. it is called a condor and has two ovens. It has a metal title plate in the back of the lower oven 2. May be Model 075E4FA10-2
Posted by Ronald Patterson on
Andrew Taylor
    Top Expert:
  • Ovens Master
  • 34,174 Answers
Condor Integra Double
EWOCIAMFBL - Condor Integra Models - Double Ovens - Chef Electric ...
www.stoveconnection.com.au > Home > Search by Brand
36758 FAN OVEN ELEMENT FOR CHEF OVENS 2400W PREVIOUSLY 1976. AUD $48.00 ... 34418 CHEF DUAL GRILL ELEMENT 1841 277mm x 400mm.
EWO9FC - Condors Models - Double Ovens - Chef Electric - Chef ...
www.stoveconnection.com.au > Home > Search by Brand 36758 FAN OVEN ELEMENT FOR CHEF OVENS 2400W PREVIOUSLY 1976. AUD $48.00 ... 34418 CHEF DUAL GRILL ELEMENT 1841 277mm x 400mm.
SOLVED: Lost my manual for chef condor integra oven - need - Fixya
www.fixya.com/support/t2385130-lost_manual_chef_condor_integra_oven Jun 14, 2009 - For TOuch Control oven: 1. Press Finish Time touch pad 2.press ^ touch pad until clock displays the required am or pm finish time. 3. how to replace top door hinge on a chef wall oven ...
Jul. 11, 2017
How to reset clock and work a chef condor fan ...
Jan. 28, 2012
Chef condor convection oven manual
Dec. 3, 2010
chef condor oven manual Questions & Answers (with ...
Jun. 6, 2009
More results from www.fixya.com
chef integra oven ' Ovens ' Gumtree Australia Free Local Classifieds
https://www.gumtree.com.au > Home & Garden > Appliances Jul 23, 2018 - Chef Baroness Integra Wall Oven and Grill Measures: 600 wide x 910 high x 570 deep Recycled Building Materials Open Monday to Friday ...
Chef Australia ' Everyday Smart Appliances
https://www.chefappliances.com.au/ Chef cooking appliances are designed to free up the time you spend in the kitchen. ... A special stainless steel finish means our ovens stay free of messy prints.
Operating instructions for Chef Condor Multifunction oven?HELP ...
www.essentialkids.com.au > Essential Kids > General > Miscellaneous Mar 21, 2012 - We just moved into a house which has an old Chef oven. and I have no idea ... CONDOR INTEGRA EW0C1AMFBL 075E11D16 M/FUNCTION
[PDF]Chef CVEP614SA Electric Wall Oven User Manual - Winning Appliances
https://www.winningappliances.com.au/.../Chef-CVEP614SA-Electric-Wall-Oven-Use... Congratulations and thank you for choosing our Built-in Oven. We are sure you will .... side of your oven. • Insert the twin pegged side into the rear access holes.
chef wall oven condoor integra double Google Search
Posted on Aug 01, 2018
5 Related Answers
Anonymous
SOURCE: chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Posted on Jul 11, 2009
Anonymous
  • 81 Answers
SOURCE: Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Posted on Nov 17, 2009
Anonymous
SOURCE: Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Posted on Jan 15, 2010
Anonymous
SOURCE: install a baroness integra wall oven
I have just brought a house and the oven is a baroness integra gas fan oven - i get the thing ignited as can see the flames but when i gently release the nosel the flames go and there is no heat. it is a little warm but i think that's just from the lamp. Any help would be great - i miss baking!:-(
Posted on May 04, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: chef gas oven user manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
Her do I find the model number on my magic chef electric oven. Red light is on staying on? Burners and ovens are all off, What's or how do I find out what's wrong?
There should be an identification plate or label located somewhere (or hidden somewhere) on your oven that indicates model.
Mar 29, 2018 | Magic Chef Ovens
I'm looking for classic chef wall oven manual please help
The manual is here
Page 1 Operating and Installation Instructions Electric Classic Wall ...
https://product.electrolux.com.au/Public/File/?Id=14896The Chef Classic oven is a compact wall oven or under bench oven and is available in the following models. Conventional oven with 90 minute ringer timer.
classic chef wall oven manual Google Search
Nov 22, 2017 | Ovens
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I need instructions for chef condor convection oven-having trouble with timer
i have a chef condor wall oven and the door wont shut properly as the latches have gone loose or broken
Jun 09, 2010 | Electrolux Ovens
Broken oven switch, Magic Chef gas oven
http://panjiva.com/Manufacturers-Of?q=magic+chef+spare+parts
It;s a global economy now, and you can order and buy spare parts from anywhere for anything. please use these links provided to source your part,and ship it back to the mother land, Aoteroa.
  1. Find the model number on the appliance to be repaired. Look for a gray or silver label on the appliance that lists the model number and serial number. If you cannot find the tag, check the locater featured on PartSelect.com. Click the link marked "Need help finding the model number on your magic chef appliance?" Then click on the type of appliance. The guide will show possible locations for the identification label, along with a sample label for visual reference. The URL is listed in the resources section below.
  2. Use the part number to make ordering simple. Look closely at the part you intend to replace. A part number will be printed or inscribed on any part that is large enough to display at least six digits.
  3. Order parts from appliance retailers. Call local USA appliance shops and ask if they sell parts. If so, get a price quote for your part and ask if it's in stock, or how soon it could arrive.
  4. Order from online parts dealers. Use your appliance model number and part description or part number to check online parts dealers for prices and ship times. PartSelect.com, RepairClinic.com and AppliancePartsPros.com all sell Magic Chef parts online. The Magic Chef website may also be able to provide needed parts. It also lists owners manuals, warranty information and installation instructions for their appliances (see Resources).
  5. Compare prices and order fulfillment times between local retailers and online dealers. Most online dealers will offer lower prices. A local dealer may have to wait for your part to ship from their supplier. The shipping time between local and online dealers may not vary.
Apr 27, 2010 | Magic Chef 9122 Gas Single Oven
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
260 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
