Question about Photography
With all the problems this camera has and the cheap price of cameras its time to consider an upgrade to a new camera. It will cost more to repair than to replace it.
Ive just seen several like this on ebay under $10 or you could join the 21st century and get a digital camera.
Posted on Nov 03, 2018
SOURCE: Loaded film, but won't work and a "3" is flashing.
The IQ Zoom cameras are designed to display error codes (E0, E2, E9, E10, E1A, E37, E90, HL, H4, H5, etc.) when something goes wrong internally with one of the mechanisms or electronic components. These diagnostic displays help to determine where the problem is. When you see an error code, ask a qualified PENTAX repair technician to examine the camera. For information on a specific error code, call Pentax customer service department toll-free at 1-800-877-0155, Monday-Friday 7:30am-4:30pm, Mountain Standard Time.
Posted on Oct 06, 2005
SOURCE: nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Posted on Feb 09, 2008
SOURCE: Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on Feb 19, 2008
SOURCE: N75/ fEE
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
Posted on Feb 25, 2008
SOURCE: Dimage E323 "system error"
remove 6 phillipscews open camera.There is a little drivemotor for the lens,next to it is a shaft activating the limit switch for lens opening and closing.Carefully spray plastic safe electronic cleaner into the opening.Now apply 3 volt to the motor reversing polarity a few times to activate the limits. Now use canned air to blow out any residue of the cleaner.This worked for me,camera working again.
Posted on Jan 03, 2009
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Apr 01, 2010 | Nikon N75 with 28-105 lens 35mm Film...
Oct 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
May 19, 2009 | Nikon N55 35mm SLR Camera
Apr 20, 2009 | Samsung Maxima Zoom 77i Point and Shoot...
Apr 19, 2009 | Nikon Lite Touch Zoom 140 ED/QD 35mm Point...
Feb 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Apr 19, 2008 | Canon EOS-30 35mm SLR Camera
Dec 16, 2007 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Dec 06, 2017 | Fuji Zoom Date 60 35mm Point and Shoot...
Jan 20, 2021 | Nikon Photography
962 people viewed this question
