Question about Furniture
I have a Kenmore model 18314242500 wine cooler that doesn't run. Getting power to unit but no clicking or other noises
Posted by raymond dinoi on
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
Anonymous
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
Ken Bledsoe
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
JIm McCrosky
  • 59 Answers
SOURCE: Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Posted on Sep 02, 2009
Rich Wright
  • 286 Answers
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Posted on Oct 08, 2009
I have a Magic Chef MCWC45MCG wine cooler that does not come on. The light works so I know it is getting power. Any idea why it won't run?
This unit is a e-wave machine, time to replace it, no parts available. Magic Chef didn't built this unit e-wave did and bought the rights to use the name to sell it. Sorry
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 12, 2014 | Furniture
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Troubleshooting kenmore wine cellar model 183.14242500 will not turn on just clicks
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 21, 2011 | Kenmore 13485 Wine Cooler
I have a Haier model BC112G that stopped working. I unplugged it overnight and it still won't work. It just makes a clicking sound once in a while. Any Ideas? Wayne
Sounds like you compressor won't come on, check you warranty status before you call anyone. This repair can cost more than the unit did. The clicking noise is the overload on the compressor witch will happen if the relay fails (rare on this unit) or the compressor locked up. Either way, check warranty status on you unit before you call anyone, maybe cheaper to replace unit.... I hope this helped..
Jul 11, 2011 | Haier BC112G Wine Cooler
Set temp to 42 and 54 but unit stays at 75. HELP!
sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
Aug 09, 2010 | Danby DWC283BLS Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Sep 23, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Furniture Logo
246 people viewed this question
Top Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Furniture Expert? Answer questions, earn points and help others
