Question about GE Washing Machines
My new ge washer machine is stock on soak, what should i do?
Posted by Karla Tamayo on
1 Related Answer
Anonymous
  • 1294 Answers
SOURCE: how to soak white clothes
You don't have to do the soaking. Use powders for 'front loading machines'. Read your users' manual. There will be settings for woolen clothes, cottons, quick wash, long wash,etc......
Posted on Jun 10, 2008
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
3helpful
Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Clothes are clean but soaked. Very slow spin
Clean out the drain pump AND connecting hoses.
GE washer stopped spinning and smell of burning out lingered
I am going through this right now and best I can tell..needs a new belt. Pop the front off of your washer (UNPLUG IT FIRST:)) and see if there are black shavings on the bottom. The appliance place where we usaully order our parts from do not carry this belt in stock so it will have to be ordered. Price from them was $19.00+ tax
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Need long term soaking for new model whdrr418gww washer
sorry I dont know by the model which washer you have. I would suggest starting washer let it fill with water and then turn it off. If you let it soak overnight I suggest you start by spinning out the load and then starting the wash process over.
How to soak white clothes over nite. have a new ge front loader washer.
Ge washer overflowing/not rinsing or wringing well
if you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Open Questions:
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
