SOURCE: WIRING DIAGRAM FOR 1984 AMC EAGLE
well you have several options you can go to a dealship and have them copy the diagram for you(i do this all the time) or you can purchase a repair manual at Napa or Oreilly's for around 20 bucks. it has diagrams and schematics in it. it also has alot of instructions in it so you can do repairs yourself. By the way i'm surprised that the mechanic doesn't have these diagrams himself. I was wandering why it won't start after you changed the plugs and wires could it be that maybe the firing order is wrong. i've done that myself a time or 2. double check the the plug wires to make sure they are in the right spot. if the problem is it won't crank. chances are you have a loose ground. please rate this..thanks
SOURCE: hooking up wires to battery, solenoid, altornater and starter
hi from the uk if you look at startermotor solenoid you will see two large threaded terminals with nuts? and a third small terminal either spade or round terminal ok? now you should see thet one of large terminals already has a metal or braides strap secured to it and the actual startermotor body? LEAVE THIS ALONE the other large terminal is the one you fit the positive+ lead to from battery also there should be another lead to also attach to same terminal this one supplies power for vehicles electrics etc ensure you secure these with nut ok? now the third small spade or post terminal you will hav a thin wire nearby ?this attaches to thisterminal on its own on solenoid this wire is the one that activates starter when ignition is turned to key start position ok? as for interior light not working ? try again when you complete the above also make sure bulb is ok? ps! before you reconnect starter wires ensure the earth/ground lead is disconnected from battery and when reconnecting battery connect positive lead first then the earth lead or if you try other way you will have sparking from pos lead as you try connecting to battery hope this info is clear instructios for you to follow and wish you luck best wishes from england
SOURCE: Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
SOURCE: i changed the solenoid in my 97 ford explorer and
this is the wiring of the basic starter motor , it may have small diffences but the logic is there...
hope this one helps.... :)
