SOURCE: my phone's key 7,8,9 and dicrease volume keys stop working
dalhin nyo na po sa nag re-repair ng cellphone.
SOURCE: Toshiba satelite m35x-s163 some keys aren't working
The keypad buttons on laptops are very sensative. It depends on what you cleaned them with, but I would suspect that you accidentally loosened or "popped" some of the letter pads out of place. You can try to fix this yourself by checking the letters you are having problems with. See if they are seated or fastened correctly. Be sure they are positioned right then apply a very light downward pressure and it should snap in place. If your not comfortable do this yourself (the keys are easy to break) then take it to your local computer repair shop. Thanks!
SOURCE: My microwave oven isn't heating
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
SOURCE: my key pad qweruiop is not working i am using a
This keyboard problem has been solved. Look at the following link:
http://www.techbuzz.in/keys-qwer-uiop-not-working-rest-other-keys-are-working-fine-laptop-desktop.php
SOURCE: The starter just stopped working
check the wires that go behind starter-that may have came out,that cause the starter to not start the car.
