I cant even go to the menu to restart factory of tv
I'm not quite understanding what exactly you are saying. Do you mean,
You have a TV, and when you turn it on, you have pictures but, you can't scroll or operate/change channels, volumes etc. by using the remote but, in order to turn the TV off, you have to unplug the power cord.
1. Check the battery in the remote
2. If the battery is good in the remote then you might have a bad remote, buy new remote or replace it with a universal remote.
3. If either not a battery or remote, then it will be the control board inside the TV quit working and will need to be replaced. Depending on how expensive or age of the TV. By the time you invest fixing the board with labor, might runs you from $200 to $400 bucks, and you can buy a new TV from Walmart a 49" inch TV for $319 bucks.
SOURCE: Closed Caption
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
SOURCE: sony tv model kv-sz29n50 trinitron
Please confirm do you see this kind of picture in TV?
Mention exact model number to help you.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
