Question about DISH Network Televison & Video
I only have paper view channels on my satellite dish Network
Posted by Roger Sharkey on
john h
    Top Expert:
  • DISH Network Master
  • 23,401 Answers
Notify provider for assistance
Posted on Jul 30, 2018
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Posted on Oct 29, 2007
Anonymous
  • 78 Answers
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Posted on Apr 30, 2008
Jim Franks
  • 374 Answers
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Posted on Sep 04, 2008
Anonymous
  • 43 Answers
SOURCE: How do I view split screen (two different channels
if it is possible (not shure) choose PIP and after that choose your source.....
Posted on Nov 09, 2009
Anonymous
  • 4 Answers
SOURCE: How do I add another TV to Dish network. I simply
What you are looking for is called a mirrored location. Its a location that mirrors either tv1 or tv2. It can be installed using simply a few splitters depending on how you want it ran. If you do it your self it will save you alot of money. If not Dish Network will charge up to $99 for a reinstall
Posted on Nov 21, 2009
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
Can I use a dish 500 dish with a VIP722K receiver Ilive In eastern Pa.
If you have a clear view of the south western sky, the receiver will receive most channels (after running a check switch test, menu, 6-1-1). You will not receive most HD (which comes on Eastern Arc satelllites not on that antenna, or on satellite 129, not on that antenna) and depending on your DMA you may not get locals, but most cable channels will be available, at least in Standard Definition.
Aug 08, 2013 | DISH Network Televison & Video
My tv's freeview wont let me view any other channels apart from the bbc
Freeview? I'm not good with tv words... Is freeview a free channel you stole from the neighbors dish (don't be ashamed)? If so, then you should buy cable (Cable's better. Really. Satellite dish companies looked one thing over. Storms ruin your tv.). If your just watching what you can get through the air, well, that won't work. After a while, you start to lose channels. Just get cable. If you already have a tv network, then you should call the tv company.
Jun 18, 2012 | DMTech DM-AV10 Digital Media Player
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
DISH Network(r) 311 Satellite System: we moved our tv and ever since we reconnected it w...
Hi myname is Mike Houston of DISH Network and I was going over your post and whenyou move the receiver you always want to make sure all connections are in thesame place. The SAT feed coming into the house will connect to the SatelliteIn, and your TV connects to the CH4 CH3 on the back of the receiver. I willsend a link that will help with these steps. http://www.dishnetwork.com/SupportSection/bbs-screen
May 16, 2010 | RCA DISH Network(r) 311 Satellite System
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
When I turn on my tv today I have this message from Dish Network: your smart card does not currently have authorization to view or order this program. Please wait or channel up or down. I just had this...
I have had similar problem, all you can do is call dish net and explain to them what has happened. They can usually send information through there satellite to your receiver to correct this problem. Your card has not received the authorization codes for your service, Each card has a unique ID that dish net can address from there satellite.
Oct 08, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
Cannot get new dish to work
You need to call Dish and have them authorize the new receiver. They may send you a new smart card depending on the receiver. Also, if there is an outstanding balance on the one you were given, they likely won't authorize it.
Jun 07, 2008 | RCA DISH Network(r) 311 Satellite System
Televison & Video Logo
60 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
