Question about Stanley Garden
STANLEY PRESSURE WASHER STARTS THEN DIES
FRESH GAS SPARK COMPRESSION,I CLEANED THE CARB BUT DIDNT SEE ANY PROBLEM FLYWHEEL KEY IS INTACT VALVE ADJUSTMENT IS GOOD.
5 Related Answers
panilling9
panilling9
  • 284 Answers
SOURCE: 4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
metal or plasic float?
Posted on Jun 21, 2009
Thomas Stewart
  • 582 Answers
SOURCE: Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Posted on Sep 17, 2009
Testimonial: "I think you're right about the puller for the flywheel. Thanks for the input."
Anonymous
SOURCE: Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Posted on Apr 25, 2010
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: troy bilt 4 stroke trimmer tb575ec won't run at high rpms. it starts, but dies when throttled up. only 2 months old, added fresh gas, checked oil, did not see adjustment screws on carb?
Hi jim gabriel
Sounds like you have dirt/debris in your caburetor jets,fuel passages
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 13, 2012
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: B&S will not start
Hi civichatch
Posted on Apr 25, 2013
IHAVE A CUB CADET 173CCOHV SELF PROPELED WON'T START NEW PLUG GAS TO THE CARB OK OK AIR FILTER OK CLEANED CARB STILL WON'T START.
got to have fuel, spark, air and compression. your missing one. be sure plug is good. give it a shot of carburetor cleaner. if it starts and dies it is fuel. check compression. take off valve cover and be sure valves are working as they should and gaped correctly.
Oct 24, 2016 | Cub Cadet Garden
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
My B&S power washer won't stay running - it starts then quits almost immediately. It has oil, it's getting air, it's getting spark, I've cleaned the gas tank and fuel fliter, and put in nice fresh...
On the Carb there are usually two needle valves, doing one at a time and carefully counting half turns. Using a small screwdriver start turning clockwise one of the screws in and count how many half turns you turn until tight. Might be 1 1/2 (half turns) to 3 1/2 (half turns) After it is tight reverse the screw and spring and remove it. Blow out the hole with a stray or air pump or wd40 spray can with straw tip. Reinstall until tight then open the amount of half turn you recorded. Do the same with the other needle valve.
Jul 21, 2014 | Briggs Stratton 020273 Elite Series...
Fuel Problem
If you have 2 carbs that work on another unit but not this one then that narrows down the fuel problem to either an intake/ vacuum leak or bad fuel in the tank.
The compression sounds a tad high which could indicate valve timing ( exhaust opening late or not long enough)
On the ignition side you could have a bad CDI , weak pulser coil or sheared flywheel key.
I believe I would lean toward suspecting the ignition. I had a Honda that gave me fits acting like a lean issue. I was in that carb 25 times if I was in it once. Same thing, idled fine but died on acceleration. It was the CDI. Put a spark tester inline with your spark plug and see if the unit dies due to lack of spark.
Dec 29, 2009 | 2003 Yamaha WR 250 F
Sep 17, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Idles rough, then turns off
might need to get the carb clean you sound like you have bad gas in your system gas does go bad with time maybe try some gas treatment with fresh gas and some carb cleaner.
Sep 09, 2009 | 1984 Dodge Conquest
My riding lawn mower won't start. New battery (cables & connections are clean), new filter, plug, rebuilt carb. It's getting spark but won't start? I cleaned the magneto and flywheel. Any other ideas?
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Jul 23, 2009 | Champion International Champion& Small...
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
74 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
