Question about Coleman Electrical Supplies
Pm0524702 coleman powermate 4200er maxa what are the dbs on this unit im thinking of buying a new one thats not so loud just cant find the dbs sound level thanks
Posted by ron rose on
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: engine surge up and down
Cleaned the carb again and set idle stop screw up
Posted on Nov 18, 2008
John Trevino
  • 1420 Answers
SOURCE: coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Posted on Jan 10, 2009
Anonymous
  • 57 Answers
SOURCE: I have a Coleman powermate Maxa 5000 ER generator
http://www.powermate.com/productmanuals.php?cat_id=3
Try this link.
Posted on Jul 30, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: how do you convert the (2) 240 volt outlets to one
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Posted on Apr 05, 2010
westburyauto
Tim Garcia
  • 70 Answers
SOURCE: Hello, I'm trying to get an old Coleman Maxa 5000
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Posted on Dec 22, 2010
Testimonial: "Advice was right on the mark! Well written advice too!"
I have a coleman powermate maxa 5000 generator model pm0525312 that needs a rotor assembly replacement. The rotor is not passing a continuity test. The rotor is 5.0 kw rf5 model 0049621.
This shows the rotor as obsolete and I'm guessing the stator would be too. Stators are in the $200-300 price range. Probably better to just buy an new generator. Jack's Small Engine shows some stators but not your P#.
Powermate PM0525312 Generator Parts
https://www.jackssmallengines.com/Products/POWERMATE/Rotors-and-Stators
Sep 30, 2017 | Electrical Supplies
Hi! I have a Coleman Powermate 5000 maxa er plus. It wouldn't start so I check out the air filter, it was kind of dirty and I found gas in it. I cleaned my carburetor with carb cleaner even if it was clean...
The engine is pulling secondary air from the torn gasket area by the sound of it. It can't govern itself like that.
That must be fixed before any further tests !
Aug 19, 2013 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at [email protected]
Sep 24, 2009 | Coleman Electrical Supplies
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Engine surge up and down
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
113 people viewed this question
Top Coleman Electrical Supplies Experts
Sheldon Dedek
MrJunk
Level 1 Expert
Tim Venetis
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
