Question about Home Security
How to bolt safe to floor - Home Security
Posted by Karen Bridges on
  • 18,562 Answers
Depends on the safe and the floor. If it is a wood floor and light weight safe, you drill through the safe bottom and then run bolts or screws into the floor through the bottom of the safe. If it is a concrete floor, you need to measure, drill set molly bolt anchors, line up the safe holes with the molly anchors and set the bolts. IF it is a heavy safe, you don't need to worry about it.
Posted on Jul 30, 2018
How do I secure my safe to the floor/
Drill holes through the bottom, open the door and mark the hole locations on the floor. Attach bolts to the wood or concrete floor, lower the safe over the floor bolts, and fasten nuts with lockwashers onto the bolts inside the safe. When the door is closed no one will be able to undo the nuts. Or use heavy duty lag screws tightened from inside the safe. This will prevent the casual picking up of the safe and slow any thief down.
Oct 10, 2014 | Home Security
I would like to bolt a honeywell safe model 1101 to the floor
Best option i see is drilling holes and using lag bolts into your floor. Depends on the floor you have. Im guessing carpet and wood underneath. Lag bolts would work fine.
Dec 15, 2012 | Honeywell Model 1101 Molded Fire Chest 015...
I haved a Sentry "Professional
Bolts can be found at any hardware store, just make sure you get the right type for the flooring it's to be bolted to, and leave the wheels on. Desiccant packs can be found at shooting supply places, but a longer term solution comes in the form of a rod that you plug into the wall which will keep the temperature in the safe a few degrees warmer than outside, thus preventing condensation.
Sep 09, 2011 | Garden
I can not locate the key for my Gary safe and the batteries are dead. Can I open it without the key to change them?
No, the key is the only way to open the safe should the batteries fail or you forget the combination.
Aug 04, 2011 | Safe International Gary Gary Personal Safe...
My Gun Safe will not open. It is a Redhead gun safe (2007?) with an electronic lock and central "star" handle. It worked fine until last week; I still hear a light "click" after I...
there are a few things that might have happened,, one thing is that the battery is almost dead and does not have enough power to fully retract the locking bolt, or the bolt motor itself has failed and is not pulling the bolt back far enough to let the handle move, or the bolt is dragging, or a broken drive gear. all these are very common problems and in the lockshop that I worked at we would get 2 of these calls a week.
there is one thing that you can try before you call a locksmith to come out and try and get it open. IF it is not bolted to the floor : try and gently lay the safe down on its side ( hinge side twords the floor -- door facing you ), now with the help of a helper,, have them hold the top or bottom of the safe about 5 inches off the floor and you type in your combo, just as the combo is finished and you know that the ' clicking ' sound is about to click, have them drop the safe to the floor,, the timing has to be perfect and this may in fact let the bolt fall back into the combo pack enough to open the door,, turn the handle quickly and open the door. if this works ( 1 in about 100 ) then set the safe upright again and with the door open lubricate all moving parts / replace the battery and test the lock 15 times ( do not close the door until you have tested the system many times ).
if this does not work then call your local locksmith ( safe tech ) and have them come out to service the lock. ( they most likely will need to drill a small hole under the dial and move the bolt out of the way and replace whatever has broken ).
c...
Jan 04, 2011 | Sport & Outdoor - Others
How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Jun 27, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
Home Security Logo
82 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
