Question about Photography
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer
Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See
for applicable file formats.
1. Connect the USB cable from the frame to your computer (Connecting to your computer).
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
to navigate to your copied pictures.
Posted on Dec 27, 2008
SOURCE: how do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Posted on Jan 11, 2009
SOURCE: uploading pictures from computer to memory card to transfer
Take back the picture frame????
Posted on May 03, 2009
SOURCE: transfer pictures
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
Posted on May 27, 2009
SOURCE: how to get pictures off sony cyber shot onto computer using usb
When using Windows Operating System on the Computer, follow the steps given below:
Connect the Camera to the Computer using the supplied USB cable. The Computer will recognize the Camera as a removable drive and list in the Windows Explorer. Press the Windows logo on the keyboard along with the "E" key to open the windows explorer. If the Sony Camera is listed in the explorer as a removable drive then double click on it to open and navigate through the files and folders. Open the "DCIM" for images and "MP_Root" for videos. Once the images and videos are visible, right click on the desired file then select copy. Next, paste the selected file on the hard drive of the Computer.
If you want to select all the files at once then press "CTRL+A", to copy, "CTRL+C" and to paste, "CRTL+V".
Posted on Aug 25, 2009
