Question about Archos Audio Players & Recorders
Archos 3 not recognized by my computer what do i do
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
Sep 11, 2017 | Archos AV400 Digital Media Player
My Archos Studio 20 device works but is not recognized by my windows 7 computer
I loaded the original software on computers with XP and Vista and neither will see the drive. Tried to get assistance from Archos but had no reply from them.
Apr 14, 2010 | Archos Jukebox Studio 20 MP3 Player
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
My archos 605 [160gb ] not recognized on my PC
I recommend trying your archos on a different computer just to see if it is a pc or archos problem. Your pc should come right up and ask if you want to charge or use the usb port or both. Try another computer.
Jul 11, 2009 | Archos Internet Media Tablet MP3 Player
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Mar 20, 2009 | Archos Internet Media Tablet MP3 Player
Archos 404 problem
Double check Archos website or helpline - some manufacturer's have a specific recovery program for such problems.
Jun 02, 2008 | Archos 404 Digital Media Player
Archos 404
Archos is not claiming compatibility with vista, even with their latest firmware upgrade - sorry
May 08, 2008 | Archos 404 Digital Media Player
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
