Computers & Internet Logo
Question about Samsung Computers & Internet
On my new 50" Samsung Smart TV, every few minutes there is a sound pop why?
Moved modem closer but still a pop often in sound
Posted by Barbra Hana-Austin on
5 Related Answers
Anonymous
  • 192 Answers
SOURCE: samsung 50 inch plasma
I have found the most common problems with the symptom you have described, to be the SMPS PCB. Sometimes the Y Main will cause the power supply to short out and lower a voltage in that area. Your set has a two year warranty. Call 1-800-Samsung to find an authorized servicer in your area.
Posted on Apr 08, 2007
Anonymous
  • 29 Answers
SOURCE: have 50 inch samsung plasma tv.have sound but no p...
If the sound is still going and you can change the channels then the problem is most certainly the ysus or zsus board.
Posted on May 23, 2010
Anonymous
  • 8546 Answers
SOURCE: Hi, we just bought a
First, is the unidentified TV the actual source of audio (self-tuning from the air) or does its programming actually originate externally, say, a Cable Box? What does the TV's manual say?
If the sound actually comes from an external source treat that source like any other hi-end audio component and attach its highest quailty audio directly to the HT according to ITS manual.
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the direction of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
Posted on Aug 21, 2011
Jose Garcia
  • 453 Answers
SOURCE: Samsung HL-S5086W 50-Inch TV comes up and turns on
you have a bad lamp , lamp need to be replace
Posted on Sep 30, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Posted on Apr 03, 2012
I have an Hisense 50" smart tv with an bunch of problems :
- Having trouble connecting your Hisense 50" smart TV to WiFi?:
If you're having trouble connecting your Hisense 50" smart TV to WiFi, there are a few things you can try. First, make sure that your router is turned on and that your Hisense 50" smart TV is within range. If you're still having trouble, try restarting your router and Hisense 50" smart TV. You can also try resetting your Hisense 50" smart TV to factory settings. If all else fails, you may need to contact Hisense customer support.
- Having trouble with your Hisense 50" smart TV losing its time and date?:
If your Hisense 50" smart TV is losing its time and date, it's likely due to a power outage. To fix this, simply set the time and date on your Hisense 50" smart TV. You can also try resetting your Hisense 50" smart TV to factory settings. If you're still having trouble, you may need to contact Hisense customer support.
- If you power down your Hisense 50" smart TV, do you have to sign back in to Netflix each time?:
If you power down your Hisense 50" smart TV, you will not have to sign back in to Netflix each time. However, you will have to sign back in to your Hisense 50" smart TV if you power it off completely.
Here are some tips for getting the most out of your new 50" Hisense 4K UHD HDR Smart LED TV:
- Make sure your Hisense 50" smart TV is connected to the internet. This will allow you to access all of the features and apps that your TV has to offer.
- Use the HDMI ports on your Hisense 50" smart TV to connect to other devices, such as a Blu-ray player or game console.
- Adjust the picture settings on your Hisense 50" smart TV to get the best picture quality.
- If you're not using your Hisense 50" smart TV, you can power it off completely to save energy.
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
No sound on tv
Unplug your tv for a few minutes might help if it doesn't, turn your tv on, go to menu, reset to factory settings.
My New Samsung 50" Plasma (PS50C451B2D) keeps
if timer is not activated, your unit needs servicing.
have the power supply check first for output voltages it may not have enough to power up some of the circuits board.
5helpful
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
1helpful
4answers
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
