Question about TDK Audio Players & Recorders
TDK Sound Cube - Black TP6701BLK upgrade problems, DONT TURN ON
Posted by Claudio Moreno Rojas on
How do i open a tdk tp6701blk
I don't know your particular unit, but I see screws hidden under the feet on many small electronic devices.
Apr 20, 2013 | TDK Sound Cube - Black TP6701BLK
Where would I be able to download a driver for my TDK mp3 player?
http://www.lostmydrivers.com/driver/download/2232/TDK/Cameras-and-MP3-Player-Drivers/tdk-mojo-128f-256f-mp3-fm-player-mojo-software---driver-upgrade. hope this helps
Nov 27, 2010 | TDK MOJO 128F 128 MB MP3 Player
Trying to replace the flasher on a 2005 honda civic - where is it? What does it look like? I've been to several auto parts stores, and each one has given me different parts - one is yellow and round, the...
it is a normally a black cube plugs into a board normally under dash best way to find it is another accord turn on flashers and locate by sound
Oct 01, 2010 | 2005 Honda Accord
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
After upgrade from Win Vista, the screen dont work on Win 7
One word DRIVERS. This is ya whole problem... simply Win 7 doesn't have the correct drivers for your PC. Unless ya have the correct drivers ya gonna always have problems. Find suitable drivers for everyone of your devices and store in a Directory, when you install, then, ya will have the correct drivers and hopefully Win 7 will install fine. Remember also Drivers can be installed in "Computability Mode" for XP SP2. Otherwise stick with Vista?
Jan 26, 2010 | Computers & Internet
Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Dec 16, 2009 | TDK Audio Players & Recorders
I rented a dvd from the red box, but my tdk dvd rewrite won't read the disk. I checked the disk, there's nothing with it. What can it be?
sometimes the manufacture at the time of the build didnt have the information for certain disks so that the drive can read them you can try to update the flash to 1.0c if you currently are using 1.0 here is a link to do the upgrade
http://www.opendrivers.com/driver/223815/tdk-aid+440n-dvw+a040212n-dvd-writer-firmware-v1.0c-free-download.html
Dec 11, 2009 | TDK (aid+440whtb) Burner
TDK DVD Rom
Heres the website. You can also try upgrading the firmware for your burner. It might help with other DVD software packages. http://legacyproducts.tdk.com/support/dvdburners/index.html
Jun 26, 2007 | Dynex DX-DVDR100 (DXDVDR100) Internal DVD...
My SONY DRU-810A DVD Writer doesn't work with TDK DVD+RW Disc
some dvd brands dont work with all dvd writers, so your option is to try another make, if that works ok then it's not a writer fault it is just that the media make is not compatable. if you start to see problems with all makes of disc then the writer laser is faulty and a replacement drive neccasary.
May 11, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
88 people viewed this question
Top TDK Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Jay Plesset
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
