Question about Power Computers & Internet
A message is displaying on my laptop i.e.,The AC power adapter wattage and type cannot be determined. The battery may not charge. what do I do?
Posted by Saikumar on
Vebble
    Master:
  • Power Master
  • 395 Answers
Make sure that you are using the correct power supply. Some have an extra pin in the middle for the laptop to talk to the supply. Make sure that you are not using the typical type that do hot have the extra pin.
Posted on Jul 28, 2018
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
Posted on Mar 29, 2009
Jubert
Jubert Ledesma
  • 249 Answers
SOURCE: AC Adaptor problems
Update your bios.
Posted on May 25, 2009
Anonymous
  • 6 Answers
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
Posted on Oct 22, 2009
Anonymous
  • 225 Answers
SOURCE: Post Boot message for my Dell Inspiron 1521
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Posted on Nov 13, 2009
lserni
lserni
  • 466 Answers
SOURCE: the ac power adapter wattage and type cannot be determined .
There are at least four possible causes for this error - (error 3600-0749, right?).
First one: the adapter is faulty. You would need a tester to determine whether the adapter is indeed supplying power. Dell will send you a replacement adapter if the warranty is still good, or you can find one online (model PA-19 PN402, 230W).
Second: one of the DC jack solder points on the motherboard cracked. You may see the error disappear by "wiggling" delicately the jack in the notebook. You either need to call Dell tech support and have the MB replaced for free (if under warranty), at cost - in excess of EUR 400 - or the jack may be resoldered, which will void the warranty and requires experience in disassembling and reassembling the laptop.
Third: motherboard is otherwise damaged (voltage regulators, buffers, and so on). Diagnostics must be performed by a Dell technician; replacement policy as above.
Fourth: you may have problems with the BIOS (if it is a brand new unit), solvable by upgrading - Dell will suggest this avenue first if you call tech support, anyway, so check you've got up-to-date BIOS and drivers.
Posted on Dec 02, 2009
AC power adapter wattage cannot be determined
The AC adapter needs to be replaced. You can buy one from Dell for about 100-200 dollars. If your laptop is still under warranty, the charger is often covered under the same warranty as the laptop and should be replaced under warranty if applicable. You may also buy a third-party charger off of ebay or amazon much cheaper, but this is not recommended. If you do consider a third party charger, make sure that it has the same wattage, voltage, everything! Good luck!
Mar 23, 2013 | Dell LATITUDE Computers & Internet
MY DELL 830 LATITUDE LAPTOP IS GIVING ME THIS WARNING,
RUN the software diagnostic ONLINE from www. dell.com for determine what hardware is fauly.
Get the support too via ONLINE by chat or calling.
God bless you
Oct 18, 2012 | Dell Latitude D830 Laptop Computer PC...
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
The ac power adapter wattage and type cannot be determined . the battery may not charge.
Access the manufacturer's web-site for your DELL XPS laptop:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&catid=&impid=&SystemID=XPS_1730
Find the Dell XPS Service Tag on a sticker on the bottom of your laptop.
On the above page, click "System Configuration", and enter that ID,
to get a list of parts, including the AC power adapter, that was shipped with your computer.
Dec 02, 2009 | Dell XPS M1730 Laptop
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Computers & Internet Logo
124 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
