Washing Machines Logo
Posted on Jul 28, 2018
My unit has suddenly become very loud and not working . Is it worth fixing ??
Whirlpool model AP51030K.
1helpful
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
2helpful
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
2helpful
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Loud humming when turned on but not getting hot. I do not get any error messages on the front screen. Model number MC18355 Whirlpool Gold GT41855skt
loud hum is caused by trans . . the mag or recit or cap has failed . . mag is most common for this problem .. **** mag and labor some times is more than micro is worth . look at replacing it .. / if its a small unit like a carry in type then most shop'w will diag for very little .. **** ..
Kenmore Model #10671192100 Refrigerator Rumbles-very loudly now.
Some kenmore fridges have a 10 year warrantee on the compressor and sealed unit. CHeck with your local Sears store if your's is one of them.
Nov 17, 2009 • Dishwashers
TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
