SOURCE: I have a whirlpool built in oven. There was a
by setting the clock otherwise oven wont work.
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
SOURCE: my built-in whirlpool oven, model
Hello &
Welcome to FixYa The problem
is with the cable that connects the touch pad and the control board, its either
bad or the clock assembly is bad itself and needs replacement. To check this
you will have to take it apart and then check the connections of cable. If that's
fine then blow air on the board. Please get back to me if you have any other
questions. Kevin
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
