Question about Jet Health & Beauty
Chair I have a jet three power chair. I have just put new batteries in it it will turn left and turn right but it will not go forward .what is wrong
Posted by Jo Greer on
5 Related Answers
Anonymous
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
Anonymous
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Posted on May 06, 2009
Anonymous
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Posted on Sep 07, 2009
Anonymous
  • 29 Answers
SOURCE: Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Posted on Mar 18, 2010
Anonymous
  • 6 Answers
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Posted on May 12, 2010
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
u need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Sep 26, 2013 | Health & Beauty
Flashing light
What set of lights are flashing, what color are they, do they flash all together or ripple left to right one at a time? Could be a low battery, the GC is in Lock Mode, etc. If the GC is in Lock Mode push the joystick forward until it beeps and then pull it back until it beeps. Release it and the controller will sound a long beep. Charging takes many hours on these power chairs.
Apr 25, 2013 | Jet 3 Ultra Power Chair
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
My Jet 3 has new batteries and they fully charge. When I am outside of the house the chair just cuts off like you turned of a switch. Leave be a while and it runs again. when you push reset button after it...
Alvin you have a left motor problem and it could be a loose connection Check that the left motor connector is tight and that if you move it the lights blink then there is a problem with the wiring to the left motor. If Medicare paid for your chair then they will pay for 80% of the repair costs contact your provider to see if they will repair it or contact a repair service like Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Mar 01, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Wife's Jet 3 Ultra ; The Owners Manual Mentions a Reset Button, but does not indicate where it is located; they have it it Well Hid. We get more information when getting a new cell phone, as far as...
liv If you look under the front of the chair below the footrest and can see the lower front of the battery tray there is a 50amp circuit breaker on the front right side of the tray. The circuit breaker is mounted in the tray and I don't know if you have access to it without removing the seat and lower shroud. I have seen very few problems with this tripping unless there are battery issues or old motors drawing too much current. Just don't put the chair in a bind like up against an object and trying to make it go forward in full speed. You shouldn't have problems with a new chair with this tripping. Hope this helps you
Nov 19, 2010 | Jet 3 Ultra Power Chair
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
