Contact manufacturer to ask your question:
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1561
Product Support
No that is not an option.
SOURCE: deleted audio recording device on my acer aspire 5050
If you still have the original disks that came with the computer one of them should be labeled for device drivers and you should be able to put that in your optical drive (CD or DVD reader) and reinstall the drivers for your audio recording device. If you do not have that disk you can go to the Acer web site and down load the driver for the audio device, or try this website: http://drivers.softpedia.com/downloadTag/Acer+Aspire5050
just make sure you choose the correct operating system (Vista or XP)
SOURCE: Retrieval of deleted voice recorded file
maybe, there are programs that retrieve deleted files, but sadly you need to buy them.
this only works if you havn't added any new voice recording (or a lot of voice recordings) or if you havn't reformatted your player.
SOURCE: Retrieve deleted messages.
yes but it would cost you several hundred dollars if not a thousand plus.
http://www.google.com/search?hl=en&safe=off&q=data+recovery&aq=f&oq=&aqi=g10
data recovery services are not cheap.
SOURCE: How do I recover a recording deleted accidentally from Sansa e250
It is possible to recover your lost recordings.
First things first: DO NOT take any more recordings with the MP3 that you want to recover records from in case you may quite possibly ruin your chances of recovery.
Then Connect the MP3 to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your recordings with Wondershare Recovery Software from the following link:
Video Audio Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Do NOT try & write anything back to your MP3 until you can recover your recordings safely!
It depends on how your hotmail was setup on your iPad. If it was setup as POP3 connection, then you can still retrieve your email using a broswer to log into Hotmail.
If it was setup as IMAP then whatever you delete from your iPad will be delete on Hotmails server as well. Double check your Trash folder to see if its still in there. If that has been deleted, then there is no way to get your mail back.
