Question about Sony Car Audio & Video
My sony exploits radio will play am fm but when I put a CD, the blue tooth or the aux. You can see that it's playing but don't have sound to anything but am fm
Posted by Carlos Canchola on
5 Related Answers
Anonymous
  • 752 Answers
SOURCE: cd play problem
Laser is dead. Call bose and they will service it for you for about $75.
Posted on Sep 22, 2007
Anonymous
SOURCE: CD/Aux play
for the "AUX input" source put it in standby mode and hold menu... scroll down to "aux in" and turn it on by pushing right
Posted on Feb 29, 2008
Anonymous
  • 129 Answers
SOURCE: No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
Anonymous
  • 47 Answers
SOURCE: The CD player on my Sony Dream Machine FM/AM CD
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Posted on Jun 26, 2009
dj_relly999
dj_relly999
  • 4070 Answers
SOURCE: can I use the Aux port to play USB in Ford audio/CD MP3 player
hi, you may use the aux port by using the right type of usb, hope this helps
Posted on Feb 12, 2010
My radio works but when i put on the cd changer it plays but no sound
Are you using an amplifier? If you are, it sounds like you are using the power antenna remote turn on (usually blue) instead of the amplifier remote turn on (usually blue/white). Leaving tuner mode when using the power antenna remote turn on turns the amplifier off.
tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 • Apple iPod touch
Popping sound coming from all speakers as soon as you turn radio on. Still plays music, happens with radio or CD or Aux.
you must test the power supply faulty a) by rizo , filter, diode, resistor. b) block from DAC, buffer, TRAnsistors, c) speakers some of them faulty or cracking.
se the diagram attached
2helpful
While playing a cd it skips to aux I have to scroll down to cd to keep it playing
Either the "mode" switch on the handlebar is vibrating or there is an issue with the auto detect circuit in the aux section of the radio. Check the bar switch first. If that is good, radio will need to be repaired.
06 and newer...contact Iron Cross Audio
05 and older...contact Radio Sound.
3helpful
How to wire a sony cdx-gt640ui in a 1999 dodge intrepid...I get sound with the tuner, but no sound with cd, aux, and usb. I'm assuming its only an incorrect wiring setup...
instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
What happened with this unit, I mean it gives me sound on fm or am, however on cd, usb, aux option does not, even though it displays in the screen it is playing.
It sounds like it could be the sound chip. If your fm/am radio is playing sound then the internal amp is fine however CD/AUX functions use a separate sound chip. Have you wired it to an external amplifier?
Radio works but cd plays with no sound
you probably have your amp hooked up to your power antenna remote. there should be another blue wire (probably blue with a white stripe) that is for amp remote.
1helpful
My Dewalt dc911 charger works but no sound?
Try and plug something in the aux. If you don't hear sound out of the aux when you plug something like your cd player in then your speaker cables have come off the circuit board or the out put transistor has gone on the radio. Sell on Ebay these go for a good price faulty.
5helpful
2answers
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
7helpful
2answers
No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
